how do i keep my amp cool? it gets REALLY hot, i have my fans mounted on it in personal ways, and like i glued them with hot glue and the glue actually melts when i get home from school. how do i keep my amp cooler? Im running about1600RMS out of am and i have a new fuse 120A fuse for power. i posted in amps but on noe answerd
lol that's cause you dint even wait you posted at 9:37 on the other one and 9:42 on this one Wow you waited a Full 5 minutes LMMAO.
take off the cover and drill 2 holes one at each end and screw them down one pumping air in and the other out the hole have to be big enough so the fan can push air in
if you dont know where it is build a small box for it and mount the fans on both sides so your creating an air flow left to right or dight to left and have some vent holes on top cause as ou know heat rises up
