ok up front iam puttin 6.5s in the door an runnin then off the stock wire up 2 the wire harness is it ok 2 run the wires in2 the wire harness an take the left side + an spice it on the right - what i mean take the right - off the wire harness an spice 2 the left + on the wire harness 2 get a 8ohm load so i can run it 2 the 12g wire 2 the bac in2 the amp 4 all the speakers
Do you mean run the speakers in series? If this is what you're trying to describe (i'm honestly not sure), then yes, you could do it. However, they're each going to end up seeing like 4-6 watts is it.. (most decks that put out "200 watts, 50x4" put out about 22 rms x4.)
