Eclipse 9122 ti
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 547
Does anyone know the recommended sealed enclousre size and the mounthing depth? I cant find it on the eclipse website or anywhere else. Thanks.
Username: Nocc1n
US
Post Number: 179
"We recommend using 3 DA7122 per sub and here are the sealed 0.9-1.25
cuft
box and ported is 3.0 cuft box with a slotted port of 12"W x 2"H x 15"L
tuned at 35 Hz"
when i was gonna get 3 of em lol
an email i got from them a while back
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 553
Wow they answered your email? Ive sent them probably five and heard nothing back. I also need to know the mounting depth so that I don't make the box too short. If you don't know then whats a safe depth to use so that the sub should fit. Thanks.
Username: Pelona
Post Number: 346
what about a 15" ti?
Username: Kd7nfr
Montpelier, ID United States
Post Number: 1423
8.5"
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 561
ty
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 562
ty. where did you find it? i've been looking everywhere.
Username: Pelona
Post Number: 348
what are the recommended sealed and ported size for a 15" ti?
and what hz should it be tuned at?
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 568
i saw someone talking anout that in a previous forum. search the forum for titanium or maybe ti.
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 569
here it is:
Jake Hill
Username: Kd7nfr
Montpelier , ID
United States
Post Number: 1394
Posted on Monday, January 30, 2006 - 07:50 pm:
Eclipse Ti can handle 1,000 watts RMS easy if you have a good enclosure. If you're going sealed, go for 1.25cu/ft. If you're going ported, 3.5cu/ft. tuned to 32Hz is the way to go. Just make sure you build the boxes up strong or you'll destroy 'em with enough power to the subs...
Username: Pelona
Post Number: 351
yeah, but they didnt say the recommendations for a 15" TI
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 572
recommended sealed = 1.25cu/ft
recommended ported = 3.5cu/ft @ 32Hz
Username: Kd7nfr
Post Number: 1425
I own a couple Eclipse Ti's left over from various installs and I grabbed the spec. sheet for the mounting depth.
Pelon: it's the same for the 15", just make sure you include the volume of the sub in those measurements... The sub takes up space, and the 15" will take up more than the 12", so include that in when you design your box...
Username: Pelona
Post Number: 352
is it alright if i put it in a 1.9cuft sealed box? You know, to bring out the lows.
Username: Pelona
Post Number: 353
i think its kinda weird for them to recomend the same size box for a 12" and a 15".
Is that the recommended size for a 10" too?
Username: Sw9152
Post Number: 7
i called eclipse and one of their techs told me that for the 15" ti a ported box should be 4.5 cu ft with a port that is 15" tall by 3" wide by 18" long, but he did not say the actual dimensions i should make the box. i made mine 18" deep by 18" tall by 28" wide and it sounds really good. and for sealed i think he said it should be between 1.5 and 2.25 cu ft (i think). not sure about the 10" or 12" eclipse ti though.
Username: Kd7nfr
Post Number: 1427
The sealed dimensions are about the same, but ported is a little different... Just stick with the 12".
Username: Kd7nfr
Post Number: 1428
And I know what the Eclipse guys'll say, but from MY experience with this sub (which is extensive), 32Hz is better. 35Hz is just too high, and stuff like Lil Jon just doesn't come out like it should. After some playing around I got to 32Hz and it'll rattle your brain if you give it enough power... Just one 12" with enough power and a good box should be enough to keep you from seeing straight...
Username: Pelona
Post Number: 364
ima go with two 15" tis with each one in a 1.9cuft sealed chamber powered by an orion 2500d.
will the amp make it reach full excursion?
and will it still have good sq or will it be too slow cuz of the added mass the 15" cones have?
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 573
Jake dont play that lil' jon too loud. it'll blow your damn ti
Username: Kd7nfr
Post Number: 1429
Pelon: they should retain pretty good SQ. And Lucas: I've yet to see something the Eclipse Ti's can't handle when it comes to music being reproduced loudly...
Username: Pelona
Post Number: 383
you think ill be able to reach full excursion with the 2500d?
Username: Kd7nfr
Post Number: 1431
Two 12" Ti's? Oh yea... and then some, in a standard enclosure. If it's ported I'd save the $ and go for a 1200D. It's when you play with the enclosure that you can really give 'em the power. Full excursion requires approx. 1,000 watts RMS. So the 2500D could power those subs all day and not even get warm... That 2500D is an awesome amp for the price.
Username: Pelona
Post Number: 402
actually theyre 15".
and with the sealed i can give them more power and get better excursion.
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 581
Jake: I guess that Eclipse makes hella better sub than Kicker. Thats a no brainer. I'm from Oklahoma so I'm kinda partial to Kicker, but I've had bad experiences with L7's. And now I have a bad impression of the whole company. There amps rock though. Way better than there subs.
