SONY AV SYSTEM RM-SS300 problems! Help please!
Username: Mandyjayneuk
London
Wondering if anybody can advise or if I need to go to a Sony dealer and pay ££££££££££ to get this sorted.....
PLease bear with me, I know nothing of technology, and in despair at me still watching a 14" portable my brother kindly gave me the above system with a big telly as a gift.
This was 4 years ago, and it's lovely - does everything I need it to do, until recently, when it started freezing when I was playing DVDs, and sometimes CDs. My brother thinks it's having problems skipping between layers, whatever that might mean. I bought a lens cleaner, ont of those cds with brushes on the back, but it's made no difference.
Does anybody have any idea of what I might try next, and is it worth trying to get it repaired, or should I go for a new system?
Would be very grateful for any suggestions
Username: Project6
Post Number: 1444
Are the CDs and DVDs clean?
London
well d'uh! I just checked the manual and it's actually a DAV-S300. sorry about that. I was reading the info from the remote control..... ahem!
London
thanks for your reply, Berny. Yes, I make sure the discs are clean.
Maybe it's the world's first intelligent DVD player - it won't play Robbie Williams DVDs but loves Bad Girls!
It just seems to have a problem with music. I'm watching Moulin Rouge right now, and it's stopping, skipping, and just went back to the beginning of the film. Gah!
Username: Project6
Post Number: 1445
seems like the auto repeat function is on. Reset the player to original factory settings. Check the manual.
London
thank you, I'll try that. Your help is much appreciated.
my sony dvd player keeps sticking when i try to play movies on it. It then goes of and a blue screen appears saying 13.00. Can anyone help me.
Bhavik Kapadia
Look i need great advise!
when i put a dvd in the dvd player, most of the times it doesnt play and the sign appears on the screen as C-13 or NO DISC!
If anyone has a solution to this problem can you please write it on the forum!
Is it worth me repairing the dvd or buying a new one?
thank you
Username: Ilver
I am having similar problems with my Sony to. I believe it is the new encryption they are using on the DVDs nowdays.
To be honest I think the Sony DAV-S300 was totally spoilt by the disc restrictions they have imposed on the system.
We bought a cheap £35 Pacific DVD player from Asda a few months back and run it through our Sony DAV-S300 on video 1 just to use the good sound from the speakers (you cant get surround sound like this). The cheap player plays anything that's put in it! And good quality picture to.
I heard there is a code that you can type in via the remote control for the Sony DAV-S300 to lift the restrictions of playing copied / encrypted discs. This may or may not be true and I have yet to find it if it's out there.
When I bought the DAV-S300 I wanted an excellent sounding DVD player with excellent picture and paid out £500 for it. The sound and picture are what I expected for my money but it was all sadly let down by this problem.
$ilver
Username: Ilver
Two interesting links
http://www.multiregionupgrades.co.uk/upgrades/oldmods/725a.htm
http://www.videohelp.com/dvdhacks.php?select=Sony+DAV-S300
Remember if you try anything it's at your own risk :-)
Username: Ilver
Also
http://www.videohelp.com/forum/viewtopic.php?t=217846&highlight=davs300
$ilver
Hi.....
i have a sony RM-SS300 dvd and i put the parental password long time ago and now i don't remember the numbers.... is there any way to reset that?? or reset the dvd it self?? please help me i can't see stars wars II.... can you belive it
atte: arturo reina
thanks
Kevin Ramsay
OK, this is going to sound really stupid but anyway. Just moved from UK to the Middle East, I've been trying to configure the DAV S-300 to play region 1 etc however it doesn't seem to accept the commands. Regardless of trying to press 1 then return it still won't play region 1 discs. By putting it on "standby" I'm assuming they mean switched on with no disc loaded.
Any pointers please
