Kicker solo X?
Username: Frobro
Whitehall , MT USA
are the kicker solo X good subs and would they sound alright upside down in the box so the magnet is out of the box?
Username: Pelona
Post Number: 443
theyre not made for music. theyre just loud as fu.ck.
so no theyre not good subs for everyday driving. but theyre good if your into competing in contests.
Username: Frobro
Whitehall , MT USA
that is what im looking for is a compation pare of subs and i dont like the w7 enther i whant some thing i can stand back and watch my windows blow out.
Username: Pelona
Post Number: 447
w7s will be plenty loud for you and sound great doing it. but if youre really competing then you should stay with the solox.
you should also try an RE MT or Eclipse Ti Pro.
Username: Alteraudiousa
Concord
Post Number: 187
if you want a loud sub that sounds good get a Stereo Integrity Mag 12 or 15. If you want to blow him away with two subs get a pair of Mag 15s. Even in a sealed enclosure these will be ouder than the W7. I had my one Mag 12(older generation) in a sealed 1.5cu ft box with 1200rms and hit 141.3 at my peak. I think Nick said he record for a Mag 12 is 152db or so.
Username: Pelona
Post Number: 460
are their sq better than a w7?
