8 volts
Username: Scott_debaker
Pittsburgh, P.A. U.S.A.
Post Number: 24
ok i notice that my capitator was readin 8 sumthin volts then i turnd da system down all the way it went bac up to 13volts or w/e then as soon as i turnd it up went back around 8 volts anit that bad
Username: B101
Queen City, NC USA
Post Number: 937
that sounds real bad, you will be clipping the hell outta your subs while you do that too. How big is your amp and wiring?
Post Number: 35
its just 10g wire an a pioneer 760w amp but b4 its was normal an now its like that but the car might need a battery cause the car doesnt start liek it should it takes a lil bit 2 start thats what i think its readin 8 cause i need power wich the car anit got
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10968
760 watts.
you need 4 gauge wire, and probably a bigger alternator.
you need the same size wire for ground and positive, and ground should be to sanded bare metal.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10969
note the battery could be damaged as well.
8 volts indicates a bad cell.
Post Number: 37
myb 8
Post Number: 38
i dnt care i ll b takin it out soon an goin 2 put in the firebird wit 8g power wire with pioneer amp wit 8g power an 8g ground so it will b better
Post Number: 39
i dnt care i ll b takin it out soon an goin 2 put in the firebird wit 8g power wire with pioneer amp wit 8g power an 8g ground so it will b better an it has 2 be the alt. an battery in that car cause the car esnt start well lol
Post Number: 44
o an the amp is only drawin 60amps
Username: N2audio
Lawrence, Ks USA
Post Number: 538
before we go recommending spending $X00 on an alt you may not need...
Can you give us the model number of the amp??
Post Number: 51
http://www.savinglots.com/lotprod.asp?item=GM5100T5.264
Username: N2audio
Lawrence, Ks USA
Post Number: 541
thanks
That amp is capable of 380w - the 760 is a max rating and for all intents and purposes is meaningless.
Unless your alternator is a hamster wheel you should have no problem whatsoever running that amp - or 2 of them for that matter.
10 ga wire isn't ideal, but there is no reason for it to be causing your problem.
If I had to guess I'd say it's just a bad connection somewhere. I would also use a DMM double check the cap's voltage gauge to make sure it's reading accurately.
Since the voltage is high w/o the system on it's almost certain you just have a bad connection somewhere between the batt (+) and chassis (-) in the amp's power circuit. Maybe a partially blown fuse?
Username: N2audio
Lawrence, Ks USA
Post Number: 542
FWIW - it's not likely your amp is drawing more than about 15A to play music at moderate to high volume.
Post Number: 52
it wasnt like this b4 i just noticed it yesterday after i turn it down it gos back up 2 13volts i dunno i b takin it out soon an goin in a diffrent car
