Tom Jo Unregistered guest | Hi I can not get Fox News and CNN How can I get them back? |
Silver Member Username: TimscarletDayton, Oh Usa Post Number: 171 Registered: Feb-05 | I have a new channel list if you are interested in it, with new updated channels, and locals, tim |
Anonymous | Hi Everyone I have the same problem, I cannot get CNN or FOX NEWS AND SOME OTHERS. What happened? Help guys! Female in trouble needs your help ! Please |
Anonymous | Tim ,I am also interested in your channel list, could you e-mail it to celicagt007@yahoo.com Thankx |
Tom Jo Unregistered guest | I even did a blind scan but still those channels plus some more are missing ??? Do I need to update anything? |
Anonymous | I am also missing channels 118 History, 139 TBS, 140 ESPN NEWS, 176 Cartoon, 183 TLC, 200 CNN, 205 FOX News on DishNetw Can anybody help please ? Blind scan has not bring any solution to me !! |
Bronze Member Username: BabakhanPost Number: 13 Registered: Jan-06 | what card are u using ?...The keys are changing..those are the channel goes first bf4 u loose everything |
Pepe Smith Unregistered guest | Check your signal strenght and quality on your echo7 |
Pepe Smith Unregistered guest | Level shud be 80 or above and quality of 99% |
New member Username: AjbPost Number: 9 Registered: Jan-06 | Those channels are active under new key.Yes, those channel have been moved for about 2 weels now .Unless you have receiver ,that you can input two sets of key(for active,future)keys,you will not get those channels unless you put the new (soon to be active)keys in.If you use the new keys now, you will only get missing channels back and loose everything else.Following keys are soon to activated key.If you don't have them, write down now,so when they have complete change over,you will have them. (soon to be keys) 00: 9e 5b 7a 77 c0 fe 91 ca 01: 4d 2a dc 33 d4 cd e3 75 |
Anonymous | For J Pear What brand and model of receiver can you input key for (active, future) keys ? How/where did you get the new keys ? Thankx |
New member Username: AjbPost Number: 10 Registered: Jan-06 | I have viewsat2000platinum,I have autoroll programed in it.So when ever the key changes the next key is already on screen.The keys have been posted on alot of different web-sites.If you want to know about the brands here is couple of site you can go in and search. totalfta.com (home of viewsat sponsor) dsstester.*om dssrookie.com(on of my favorite) keys are posted front page of this site.Alots of people wait too long to write down and when they change the keys it is really hard to get on this sites for about a day or so... |
Anonymous | Thankx for your information on this J Pear |
Bronze Member Username: AjbPost Number: 17 Registered: Jan-06 | No problem |
Adam P Unregistered guest | For J Pear I have a pantec mx and I still have the 256c bin on it (which i have to add keys(00 01) manually. Is there any safe bin for this box to cover both active and future keys(or with autoroll)? if yes, where can I find it Thanks alot |
Bronze Member Username: AjbPost Number: 18 Registered: Jan-06 | alot of people have different opinions.latest fix is 271t but some people have said its killing there colone.I don't have pantec but I have been reading about them and I think safe bet is 270t.It has autoroll.factory default your receiver,download new bin,antenna set up,scane the bird,wait few minutes for it to autoroll.Enjoy pantec2fa.*om(* is for c) |
