Archive through February 06, 2006
Username: Lklives
Post Number: 220
Use bin 137 with autoroll for that pansat 3500...it works fine...its at dsscommunity. c om forums "pansat" area..
Username: Madisa_paul
hi
i need help with my fortec star lifetime ultra
ill try to flash my receiver after the download
complete message come says flash burning
now i cant download channels averytime i click
the ok key the receivers cut off
please help me thanks
Username: Kosovari
Hi LK, i see you been alot of help to alot of ppl here, maybe you can help me out too. I have the 2500A and i have lost all the bell expressvu channels. Can you help me to flash the receiver or wut ever i have to do. I never did this so i dont wanna screw up the receiver. Thanks alot, your help will be greatly appriciated. :-)
Username: Kosovari
O and if i have another dish that i use to watch sum european channels ... i looked at the site lyngsat(.)com and how can i set so i can watch channels on with Eutelsat W2 at 16.0°E with the 2500a.. i donno if that makes sense at all :-(
ps. on pansat2500a. i dont see Eutelsat anywhere :S .. even tho i had TopChannel, MIA, and RTV21..thnkx again
Username: Lklives
Post Number: 245
Forget 16 E, U're not going to get it!
To get Bev back (U were watching it), upload the 267 or 270 autoroll bin, and the keys will roll into place and do a scan again..
Username: Kosovari
Hi again, Where can i get the 270 autoroll bin, and how do i do it?
--- I used the T-5/KU and i used to get 3 channels (TOP CHANNEL, MIA, and RTV21) but they locked them down like a week ago.. and agian this is a different dish..
Username: Lklives
Post Number: 248
LOad it like any bin...its at dsscentral.ne*t..pansat..
Username: Kosovari
is there a way of just entering the KEY? since i dont have the cable here yet..
Username: Kosovari
which loader should i use?i have the 2500 downloader and the blacklist updater... and this is the bin that i have.. X-85BL_051225_270t_au_api(N).bin .. is that oki?
Username: Lklives
Post Number: 249
U cannot load ANY bin without the cable...straight cable for the 2500...and use any loader U want...BL 1.4 is simple..and yes, bin is good too..I prefer the BL updater..but U any U want..
Username: Kosovari
Post Number: 7
sorry to bother again, but wut about T-5/KU 97.0 West. The channels are nagravision and irderto or sumthing like that encoding. But they lockd them, would the bin get those channels back?, or would i have to do something else
I asked b4 but i didnt get an answer yet so please somebody reply to me ..... I have Foretec Ultra reciever and i wanted to know if it is possible to get the NBA league pass channels to work.....they show as scrambeled now
tonyN
i need help , i've been entering a code under nagravision getting my normal channels fixing it every time ... but now it says No signal???
i tried entering the new codes but it keeps showing tht message and im not sure what to do , please help me
Username: Kosovari
Post Number: 9
new keys for Irdeto 2 and Nagravision?? anyone?
kwazy4fta
need help trouble shooting...
have pansat 2500
just enter new key:
N1
00- 20-8F-2C-9B-8B-EA-0D-A3
01- 01-0D-A7-91-20-52-96-EE
N2
00- FB D9 F2 D9 D6 C9 EF 7A
01- 57 AD 32 24 67 42 6C E6
for 119
level is 75%
quality is 35-39%
still gets scrambled or bad signal on every channel ! am I missing something here ?
don't tell me the keys are changed now :-)
thanks.
Im new ,Please help me I needs pansat 2500A autorolls zip and how to use what progam to laod.
Username: Tweakerttweaker
Man oh man, nothing ever changes on one will read older messages to learn something thats being ask 100 times before. There is GREAT info in the older messages, it does not change, Please, search, search, and read read you will not have to take the easyway out and ask! Eventually no-one will answer other-wise. Sorry, I just could not take it much more. Tweaker.
Don't get me wrong glad to help, but geezzz....
eral
need help lost my singal
eral
anybody know if a bad bin file well nockout my sat singal i was up and runing don;t no what happed?
Username: Dererere
how to get iderto channels up and running they
are always scrambled??????? please help
Username: Lklives
Post Number: 310
U don't!
INeedHelpPls
Anyone i need some help...pls... i put in the right codes in my fortec receiver and i got like 90% on both my signals but there is no sound or picture although the satellite guide does show wats comming up next and show timmings...?
Username: Kosovari
Post Number: 14
What do i have 2 do for these settings?
LNB Type:
LNB Local-Freq:
22Khz:
DiSEQc:
SKEW:
TP:
Positioner settings:
I have the 2500a and want to get BEV and DishNet..
and which sat do i select?
Nimiq 2? 1?
echo 8.6? 7? 6? 3?
Username: Cartzu
hi, i need help ,just put in new codes and its not work,all cha.scrambled...i have a pansat2500
.somebody help me please
Username: Lklives
Post Number: 327
Simple PanSat FAT Receiver set up Guide ****
I hope this instruction will help you get started: Read the instruction and understand all the procedures first before you starting to flash your receiver.
Before we getting start, you have to down load all the software you will need and install them.
Down load the file you need from below link, then create a folder, and save as any name you want ( I name my Pansat Utilities_Programming), then unzip the file into the same folder.
Pansat FTA Loader: Get your PanSat loader here
PanSat FTA N2 Flash: Get your PanSat FTA Newest N2 Released
Channel Master: Get it here
Receiver Software update:
1. Connect the serial cable to the receiver and Comm #1 or Comm #2 port of your computer.
Double check and make sure the cable is securely connected.
Note: Pansat 2700 & 3500 use RS232C null modem(serial)cable and Pansat 2500 use RS232C straight through serial cable
2. Plug in the receiver power core, make sure the switch is turn to "ON " from the rear panel,
Then turn the power ON with remote control or from the front. You have to wait for receiver to boot up and
indicated ON.
3. Run the Down loader GTRom Loader from the new created folder.
4. Click the BIN FILE button, browser and select latest BIN FILE, then click the Open button.
5. Click the Download button, wait until the Download Completed.
Watch the LED on the receiver, it should reboot itself, wait until receiver displayed ON.
6. At this point; You are done with the software update. You can turn off power, then disconnect it from the PC.
Receiver Configuration set up
With the Receiver unplug
1. Connecting all the RCA cable from the TV to the receiver, and connect RG-6 Cable to the receiver, then
Plug in power cord on the receiver.
2. You should see the Language Menu on the TV screen, select English.
3. "CAS SYSTEM" set up, just following the 3A, 3B and 3C steps
3A). Press menu, scroll down to select Parental Control then press OK.
3B). Scroll down to PIN #2, then enter you 4 digits password.0000
If you enter correct PW, it will take you into the CAS SYSTEM menu windown.
3C). In the CAS SYSTEM menu, scroll down to SET DEFAULT KEY, then press OK. Then exit to main menu page.
In the future; if you have to edit the Dishnet key, just following the step #3 to get into the CAS SYSTEM menu,
to edit the key go here Here is how to update key with a screen shoot
4. From the MAIN MENU: selecting INSTALLATION then Antenna setup Option.
These are my dish set up and DiSeqC multi switch configuration;
DiSeqC #1 SuperDish Echo9-IA 13 Dishnet 121
DiSeqC #2 Echo8.6/Ku 110W,
DiSeqC #3 Echo7/Ku at 119W
Satellite: ECHO 9(121) same as dish 105
Lnb type-Standard
Lo freq-10750
22khz-OFF
DiseqC- #1
Skew: O
TP: leave it as is
Positioner-Disable.
Satellite: ECHO 6,8(110)
Lnb type-Standard
Lo freq-11250
22khz-OFF
DiseqC-#2
Skew: O
TP: leave it as is
Positioner-Disable.
Satellite: ECHO 7(119)
Lnb type-Standard
Lo freq-11250
22khz-OFF
DiseqC-#3
Skew: O
TP: leave it as is
Positioner-Disable.
5. Check the signal and Quality level highest as you can (adjust the dish slightly to improve the signal strength).
If you get no quality level on transponders, try others before giving up, because not all TPs are transmitting,
if nesscery Re-aim your dish still not getting any quality signal
6. Press the Exit button, press OK to save setting, the back to the Main Menu
7. Go back to the Installation Menu
8. Goto SATELLITE SCAN or BLIND SCAN, press OK, select the satellite to scan.
you have to scan all the satellites have, once it complete, you should be able to watching TV
Username: Lklives
Post Number: 328
This Guide will work for both Pansat 2300 (with X-7500 files) and Pansat 2500 (with X-8500 files).
This Guide is for a "Basic Setup" - 18" DAVE dish, ONE DAVE LNB, ONE Satellite.
For other dish's, Different LNB's (FTA LINEAR) (and LNB's with switches built in), switches and multiple LNB's/Satellites, there is a little more to it than this Guide.
If you have a DishPro500 setup which has a built in switch at the LNB's you will have to do more work to get it running. You will have to use special Channel bin files that include freq's to demultiplex the Stacked signal you get from this type of Dish.
Do a search for Dishpro on this Site.
Setting up this receiver for ~~~~~~~~~~~ is not hard at all! You MUST follow the instructions. They MUST be followed IN ORDER.
If you don't know what each one does and or not sure if you have done it correctly you CANNOT just go on to the next step and expect things to work out. IT WILL NOT WORK!
The loader programs and the latest X7500 / X-8500 Files are in the Downloads/Pansat section of this Site.
Make sure your Com Ports work on your computer and baud rate set to 115200, if they do not, or, if they are configured incorrectly or blocked by a firewall or Norton you cannot flash your receiver
1. Flash your Pansat 2300 with latest X-7500 / Pansat 2500 with X-8500 bin file. (This MUST BE DONE to DESCRAMBLE the Dishnet Nagravision1 signal). Use a RS232 Serial Straight Through Cable and Com Port 1 on your computer. Use the flash utility uploader and X-7500 / X-5800 flash file. Download the X-7500 / X-8500.bin to the receiver from you computer as a "Flash ROM File". DO NOT, I repeat, DO NOT DOWNLOAD IT AS A "BOOT FILE" or you will fry your receiver and you will be finished with it and these instructions!
Make sure your Computer says "Download Complete", not just 100%. If you don't get "Download Complete" you have NOT completed the Flash! WAIT WAIT WAIT....for your Computer to say "Download Complete" and the receiver should re-boot itself. If this has not happened, you have not flashed successfully. Do NOT go further!
2. In antenna setup, select satellite you want (birds E8.6 at 110W and E7 at 119W are the Dishnet birds), select transponder #11 for bird 110 (Echo 8.6) or #17 for bird 119 (Echo 7) (whichever you are looking for). (This MUST be done because we know that these transponders actually are transmitting now). If you get no quality level on these transponders, try others before giving up. Not all transponders are transmitting all the time. MAKE SURE THE CABLE IS PLUGGED INTO THE "IF INPUT" PORT ON THE BACK OF THE RECEIVER! Plug the other end directly into the LNB on your Dish.
3. Still in antenna setup set LNB to "Standard" and freq to 11250. (This MUST be done to receive a QUALITY signal from the Satellite).
4. Still in antenna setup, rotate your dish to find the satellite you have selected, watching the QUALITY meter at the bottom of the screen. Get this as HIGH as possible. (This MUST be done before trying to do #5). Keep in mind that just because you told the receiver you are looking for sat 110, it does not know the difference in the signal it receives! Therefore, you MUST have some idea where 110 actually is from your location. Your receiver will show a quality level from ANY satellite that you actually have your dish pointed at.
5. Scan (ALL) for channels. (This will load the channel list from ALL transponders transmitting on the satellite to your receiver). I DO NOT ADVISE loading/using someone else's channel list, if you do, you are asking for trouble! Unless you are using a DISHPRO 500 antenna,...if you are, search this site for info on this DISH and the requirements for a channel list to demux the stacked transponders. At the completion of this scan you will have channels showing in your channel list. The ones with "$" are the ones that are scrambled channels. All the others with just names are "Ghost Channels" and can be deleted later on.
6. Go to parental control and at the bottom of the screen you should see "Second PIN" available. Enter "0000" and it will take you to a screen where you can turn the EMU ON and SET DEFAULT KEYS ON. (This activates the keys in the x-8500 flash, in item #1 above, to decode the signals). This cannot be done until you have channels in your receiver. Just turn EMUON and Set Default Keys and hit OK. Exit out of the menu and...........
7. WATCH TV!
You can now go back to your channel list and delete all of the channels that do not have a "$" in front of them, they are "Ghost Channels". Rename all the "$" channels to whatever what they are.
Username: Ttazz
I have a 2700a pansat need to find out why it turns on and off by itself can any help me please
is thier a new bin for the 2700a pansat.if so what is it please. thank you
LK i see u answer everybody's questions but never answered mine although all the questions ur answering are very repetitve. i asked a simple question regarding Nba channels but u refused to answer. Thank you anyways
Lk,
You know how you gave explicit directions above of how to install your dish and program it, can you please give step by step of how one would go about downloading the new autobin 267 or 270 for a pansat 2500A. This will be greatly appreciated.
Thanks
Username: Lklives
Post Number: 345
For sports channels...read the "sports package" thread!.....it might be in ARCHIVES here now....U must scan the TP's at game time..I have answered that question 100x here,if U had read!
Loading a bin is explained step by step above..Can't U read!
Then turn the power ON with remote control or from the front. You have to wait for receiver to boot up and indicated ON.
Hello Everyone!!
Does anyone know the new key codes for Fortec Star? I have been blanked out. Please anyone help.
Your response is very much appreciated.
Regards
PMN II
Please help urgently. Anyone know the new nagravision codes for SABC?
About a week ago we got the "new" codes emailed to us b/c our dish went down. The codes starting with FB D9 etc. Well those didn't work and our sat. guy said they don't work a day later. So we unplugged the Sat and just have been using cable for a week....so this morning I decided to check what you all had to say and double check the codes we had gotten etc. So I went and turned the Sat on just planning on double checking the codes and the damn thing is working. SO I go to the codes page and another set of codes has replaced the ones I entered last week.....
9E 5B 7A 77 C0 FE 91 CA
4D 2A DC 33 D4 CD E3 75
Does anyone know if this is like the default b/c I had the power off to it for a week or what? I mean it works so I'm not complaining but....can someone explain?
LK,
Thanks for the instructions on how to upload a bin. I have a questions about step 3, is a GTRom Loader something that pops up when I hook up the reciever or is it something I need to download from a site prior to starting the whole process? If it's from a site can you please advise exactly which one.
Thanks in advance
Username: Lklives
Post Number: 359
Nic..the FB D9 code is STILL good and is the ACTIVE key that needs to be enetered.....your sat guy is NOT knowledgeable at all..If U have a co*olsat or viewsat then U need both the 9E-4D along with the FB-D9 (4 lines), otherwise U only need the FB-D9 codes (2 lines).
GTRom loader is software file..there are many other software loaders U can use too...I like BL 1.4 updater file myself...these files are located at any other DSS site...dsscentral.n*et has them and more ..
LK,
I'm confused...I have previously done a GTRom download within the last month....what is this about needing 4 lines instead of 2. I only have 2 lines where I can enter the codes and I tried the FB-D9 codes and they did not work and now somehow the other code I noted is has now replaced it. I have a Pansat 2700.....
Username: Lklives
Post Number: 364
Nic...Last time telling U ..FB-D9 WORK!...no others do work!!!! U don't say what bin U have or provide any info...make it simple, load the 140 bin...its posted at ALL DSS sites!
load 140 bin (its an autoroll bin)... loads like any other
scan satellites
set default key (not manually input)
wait for keys to roll
watch TV..
U have alot of reading to do...those are working keys (2 lines)..I have a thread here on how to input them...its VERY simple..if U were using a bin that does not have the autoroll then U would need to input them
LK thank you although u gave me hard time. The NBA channels work i did TP scan when the games are on. But some were not on and every time u do TP scan u get the same channels stored again so u get same channels twice. HOw do i avoid that when i TP scan again to get the rest of the channels....Thanks
LK sorrry man forgot to ask ?? Do i have to do a TP scan Every time i want to watch the game cuz i notice the channel goes scrambled / bad channel after the game is done. I didnt find the Archieve for sports package i looked all over ....thanks
LK never mind i found that Sport Archieve FINALLY... But i want to know how to avoid duplicates when u scan TP....thanks
I have a pansat 2500a and cannot get channel 471. I have updated my receiver with the latest bin 270-au. Can someone please help? thanks in advance.
dumbdumbdiddy
I have a viewsat. Under Nagra it has two of hte following: "dish" and "Dish." One has 2 lines of code and the other has 4 lines. I put the two lines of code (FB-D9 and 57-AD) but it still didn't work. Plus I thought this box did autorollover? Can someone help?
Username: Cartzu
before the cods change,my sat,work fine ,i put in the new cods and all chanall are srambled ,what i need to do
Username: Un_antillais
StCroix V.I, V.I V.I
Is there a pansat bin for canalsat
any one with nagravision codes and also for dish network sabc,etv, mnet,
I have Fortec Ultra i would like to know whats the maximum dish's u can have on one reciever. can u have 5 or no ?? thanks guys in advance
Anyone know what has happened to future-fta.c*om site? its been down for a while.
Username: Trof
Future-FTA.INFO is the new domain for our sister site and we hope to see you all joining us over there.
Can anyone give me the latest nagrivation codes for SABC and etv.
RED EYE
I live at KENT ISLAND MARYLAND 1 mile past BAY BRIDGE.I have a Stab HH100 motor.I will pay $60.00 dollars per hour to a person that can install this motor @ tune in FTA Satellites.My E-MAIL tony1935@msn.com
I live at KENT ISLAND MARYLAND 1 mile past BAY BRIDGE.I have a Stab HH100 motor.I will pay $60.00 dollars per hour to a person that can install this motor & tune in FTA Satellites.My E-MAIL naxos1935@msn.com the correct E-mail
Killed the Pansat!!
Hi, since this seemed like a good thread for someone to help here goes: My friend recently purchased a Clone Pansat 2500a. He put my Pansat 2500a (original) bin into it. I told him that it would kill his box but he said to continue. Now his box freezes up. Is there any way to fix it?!?!? Please help so I can finish this off. Thanks
Jamal
Hi LK, I tried searching for that "sports package" thread but im unable to serach that thread..can you post it again. just want to find out how can I enable NBA league pass. thanks in advance
Username: Lklives
Post Number: 460
Sport Packages Channel Info.
The available games that make up The Sports Packages are in addition to those seen on FOX, ESPN, ESPN2, regional sports networks, and your home team's television affiliate stations .
The NBA, NHL and MLB package channels (540-552, 561-572 and 625-639) change transponder/satellite positions daily. They are all mirrors of the Regional Sport Channels found on channels 412-437 ..
The "'SKDL 1-8"" channels are all on Transponder 24 frequency 12559 h 110 W . and "SKDL" Channels found on channels 9910-9917.
These are the transponders that are needed to be scanned either 1 hour or during the game time ,, in order to receive the NBA, NHL and MLB package channels broadcast.
These channels will always be in the following places: Transponders 10 , 12 , 17 , 18 or 21 at 119° and transponders 24 or 25 at 110°..
Frequencies will be as follows @ 119W: 12355 H , 12384 H , 12457 V , 12472 H , 12516 V .
Frequencies will be as follows @ 110W: 12559 H , 12574 V
Choose menu on remote control, then select installation, tp scan, select 110 or 119 and in new screen choose the tp/freq you wish to scan..then click ok...do this an hour before or during the game...
_________________
for 520-533 scan these:
12253,12530,12632 and 12661
for 550-575 scan these:
12355,12471,12515,12559
This is for a non-dishpro setup.
For 520-533:
If you have dishpro then take those numbers above and subtract them from 25600. So for example 25600-12253= 13347 for dishpro. Scan tp frequency 13347 and continue for the rest.
For channels 550-575:
Scan these transponder numbers :10,12,17,18,21 on 119 and 24 and 25 on 110
If it is the sports channels you are after you could try the following to save scanning all the time:
The above transponder numbers listed are also the transponders for the following channels:
1. FOX Sports regional channels (409-437)
2. Sports ALT channels (445-452)
3. SKDL Channels (9910-9917)
Most channel lists will already have these channels in the list. If you don't have these channels in your list then get a new dishpro channel list.
Here's what to do:
Take that group of channels above and mark them as favorites in your channel list. Call it whatever you like. Now when you're looking for a game, just go to the favorites list and you'll find the game you're looking for in one of these three locations. If you don't find it, DN is not uplinking it.
What DN is doing is taking the games from those transponders and merely adding another SID to the uplink. That second SID will contain a number somewhere between 540-548 (for the Hockey games). That is how the game is being broadcast on both the regular feeds and the package that DN calls "NHL Center Ice". Once the game is over, the secondary SID uplink is taken down.
This will stop the unnecessary pre-game scanning and you can start enjoying the games. This should work for all NHL, MLB and NBA games
Dishies
Freezing-- Everytime I try to watch something my pantech reciever keeps freezing and then needs to re-download to get the picture...how can i fix this? thanks.
vamcouverman
Looks like charlie sending 4 key codes with one of them been a fake?
Autoroll attack.
Gusyehia
Hey Lk,I have been on countless forums and reding through you are clearly the smartest person on the matter i have see. Having said that, i have a pansat3500 and 2 satellites and i get international channels and the domestic channels but my dish stopped working...some ppl say it got zapped and i usually get some guy to fix it but he takes too long so how do i reprogram it myself to have the most possible channels and save some of the money this guys always charges...your help is greatly appreciated...please be detailed as i have not done this before
hi my pansat 2700a freezes,it works for one min and then stops,pl help me solving this prob,LK may u have solution for this,pl guide me step by step .i'm new with this
vancouverman
If you have autoroll, you are under attack by charlie. U will need a upgrade, but if you dont have autoroll, then u are ok.
The picture will freeze, then u turn off and on
and it goes to start up and freezes. Options are go back to no autoroll bin and u will be fine.
New bin is out for correction. this is charlies last ditch effort cause you can only go 4 key codes.
what can i do? I need to see a soccer match this morning. by the way what is BIN?
Username: Stupidbush
Arkansas, Arkansas Bangladesh
Post Number: 36
bin 318
Username: Le74nguyen
Perris, Ca Usa
Post Number: 62
anyone help pleessease. I missed national free channels-Does anybody have files for update?
Username: Tonymack
Post Number: 8
Hi: Does anyone have the lastest bin for pansat2500a.
My receiver just keep trying to download picture but won't acquire them
justwantmytvback
any 1 please help . i have downloaded the 222 orignal bin to clear out all code bits to flash my box with the new bin that came out last nite. but after downloading my reciever comes on but is frozen wont let me go into the menus or do anything can any 1 help ? it would be much appriciated. thanks
whoootv isback
a new 271 bin works just fine folks dsstester. c o m
Username: Tonymack
Post Number: 9
Hi everyone: bin 271 for pansat 2500a is available at
www.mcidss.com
Username: Tonymack
Post Number: 10
www.mcidss.com have bin 271 for pansat2500a
HaXiT
i need a n2 key for the fortec star reciever
My pansat 2500a has N2 autoroll and it appears to have a problem with picture interruption and autoroll rolls every minute. Any FIX
Username: Mkaamir
I have a pansat 3500s it goign on auto roll it finds the key and then after three or five Min it goes back to autoroll and looking for keys
i tried to flash it but it it wont take a file or let me write back to PC all my other reciver works fine cable is good port is good only this reciver is not leting me download a file now no error given just sits at Zero.
Username: Trucker
Post Number: 18
there are autoroll patches, posted at other sites.
Username: Kosovari
Post Number: 23
wuts the difference between the 271 bin and 271T bin?
Username: Orly
Toa Alta, PR PR
i need new keys for pansat 2700a has of 4 feb 2006 the that it has are no good can someone help me?
Username: Lklives
Post Number: 471
DN has found a way to attack the autorolls...BOTH DN and Bell are rolling 2 sets of keys every few minutes in preparation for the Superbowl...thats why they keep rolling, pix freezing , etc...use an older bin file with NO autoroll and manually input the keys...the keys are the same since 20 Jan..there is a thread here explaining how to input the keys..READ it
N 0101 00:
N 0101 01: ...Active key
Pansat just released all new autoroll bins late last night that are working!!...www.dsstester.co*m has them all..also have a new clone safe 271T bin, good on older Ultra's , pantecs, eaglestar, new Ultra's with resistor mod etc....
rooky
anyone have new keys, starting to lose channels.
romo
Hi LK, do you know if the fix for autoroll (bin 271) posted at d s s tester. com is working for DN also? It mentiones only the BL and that's the only file that I found dated as of today. Thanks a lot.
HI LK HOW I CHANGE TO NO AUTOROLL I HAVE PANSAT 3500.. THANK YOU
llllll
Hi LK i would like to buy a new Reciever which one do u recommend ???? there is alots of choices and im not sure which one is goood ??? viewsat r coolsa*t or Pansat or Fortec please let me know of ur opinion thanx ......
Username: Lklives
Post Number: 484
All the new Pansat autoroll bins are working
271 is for DN and Bev and does work for the 2500..the 143 (2700) and 239 (3500) are there too at dsstester and dsscommunity/dsscentral
buy new?..coo*lsat5000..viewsat Extreme or pansat 3500....all are good..right now the Pansat is the only one with a working autoroll bin (always has good available software)...I wouldn't consider anything but those 3..all cost about the same ...$165
new bin 143 on dsstester working properly on my pansat 2700a.
SR
Hi
I have Pansat 2700A programmed with Bell* Expres went down few days ago, I think it had auto roll in it. Can someone please tell me bin 143 would work with Bell expres? And or I do need a different key for Bell..?
Thanks
Username: Lklives
Post Number: 501
There are NO new keys!...DN is messing with autoroll bins..U have 2 choices..applies to all types receivers..
1..use an older bin and manually input the ACTIVE DN key ...twice
2..use present bins and disengage the autoroll by simply renaming the satellites (Echo7 to Xcho7)
In pansat..menu - installation - edit Tp/sat
now select your sateliites and rename them..exit
Pansat has all new autoroll bins that work but need to rename the sats with the 239 pansat3500 bin..
Bev keys changing constantly..U MUST have a keymaster utility to try and keep current.....even if U have new bin!
Lk i changed the name but the satilgith is stilllosig the connecion
Help Help
I flush my Pansat 2500a with bin 143 did not work, then bin 271 and did not work. The autoroll keeps rolling from 0% to 970%. What else can be done. By the way my pansat is clone.
lost2314
Can we wait this out untill the Superbowl is done .......?
SR
Please get me some info abt Bell Exp.... on pansat2700A,,, whats the right program and key for it?
I really appreciate your feed back
SR
Username: Missyj94
Allen, KY USA
i have pansat 2700a my channels will work for a minute then go out and then it pops up and said wait for picture then it goes threw all these percentages and then it will pop back on for a minute and then off again. How can i fix this?
armenio
Hi guys, I have fortecstar lifetime ultra receiver in IA 5/Ku Satelite, there is any code vor nagravision 2 or bin file or anything, I think is globalcast and I tried with dish codes doesn't work even I downloaded latest bin files from dsstester but nothing. Please help me
Username: Lklives
Post Number: 514
Missy read above..the fix is above U with older NON autoroll bin or autoroll bin and rename the sats..
anybody know how to off autoroll from the viewsat receiver pls help me out
thanks
Username: Lklives
Post Number: 519
yeah...either try to rename the satellites or upload an older NON autoroll bin and manually input the keys..
troneman
tried a few bins with pansat 2300 - none seem to work - any suggestions? testing 2500 working great with 271 bin (not sure if its autorolling)
thanks
I fixed most of my problem myself and I am a novice at this. RENAME your Satellites. Listed under edit, when you have renamed be sure to hit OK. Next enter N-2 Keys manually. Then re scan your newly named satellites. Works for me and I don't know hardly nothing.
Username: Missyj94
Allen, KY USA
LKlives
you are going to laugh I hope I dont know what that means.
Username: Lklives
Post Number: 530
Missy..If U can READ, then I suggest U start now...go read about Pansat setup Guides and posts atbevery DSS site...dsstester and dsscommunity are 2 good newbie sites..come back in a few weeks then U will understand what foreign language we are speaking to U now.... its either that or find a boyfriend to do this for U..
BTW ...NON means = does NOT...Autoroll means= automatically rolls and changes...rename means= I will call U Sissy now instead of Missy....sat means = satellite..
Username: Khanmaida
Ontario Canada
I wanted to upload a 102t file on my fortec ultra, and I normally use a 282t bin file. I'm still a bit new at this but what I do know is that if you'v never used a 101t/102t file on fortec ultra b4, you have to change/reset default keys (I think). If I'm trying to upload a file
"Chancysand Ultra_Pan_102t_12Hr_clock_ir_Nag2_Lightning_012706_(NTSC).zip", I have to change the keys (on my current bin) at 'Channel Edit', but I dont know what I have to change exactly, and what should I put there to be able to upload that 102t file, please HELP!!!, any help would be greatly appreciated.
Thanks Alot,
May
I have a pansat 2500a and I have loaded bin 271au. Everything seems to be working fine except that channel 471 (ppv sports) keeps on freezing/flickering. Every other channel comes perfectly fine except PPV 471. Can someone please help. thanks.
