I HAVE : Receiver Model -- 2 FORTEC STAR LIFETIME ULTRA Software Version --257 H Diseqc Settings -- 2 switches for 4 lnbs (1- 119, 2-110, 3-61.5) Dish/Dish's -- 500 for 110,119 and 61.5 Lnb/Lnb's -- Network/Satellite --dishnetwork i have very strange problem - i have 2 receivers in two rooms and when im watching 61,5 sat in one room on second receiver im loosing signal switch problem????????? or any other ideas?
U need to be using Dual LNB's (1 eye but 2 outputs from the 1 LNB)...so U need 3 LNB's if U are tring to get 3 satellites on 2 receivers...
run 1 cable from each LNB to 4x1 disque switch to #1 receiver
now do same thing to #2 receiver....run 2nd cable from each LNB to #2 disque switch to # 2 receiver
lastly configure the antenna and switch settings in your receiver installation set up..port 1- 119, port 2- 110, port 3 - 61.5 etc..
SO in summary... U need 3 DUAL LNB's 2 4x1 disque switches
GAGA WALBRZYCH
hey LK THANK YOU !!! i have dual LNB FOR 61.5 AND I HAVE ONE LNB FOR 110/119 WITH DOUBLE CABLES GOING OUT (for 2 separate rooms)so from that LNB i have 2 cables from 110 and 2 cables form 119. I hope i explained good for you. and 2 got 2 4x1 disque switches. THANK YOU FOR U QUICK ANSWERS -im wating for more
