Kicker L5 900w
Username: Chevelle
Lancaster, Pa Usa
Post Number: 39
Question i got a kicker L5 900w now it pops at high volume any ideas guess thats why it was so cheap.
Username: Goatin
U.S.A
Post Number: 172
what size is it and your amp?
Username: Chevelle
Lancaster, Pa Usa
Post Number: 44
kx550.2
Username: Goatin
U.S.A
Post Number: 173
is your sub 2 or 4 ohm
Username: Chevelle
Lancaster, Pa Usa
Post Number: 45
that i'm going to have to take out the sub to see how it's wired i got it use but it's not all that old
Username: Goatin
U.S.A
Post Number: 176
if your sub is 2 ohm bridge your amp and wire your subs like diagram 2 in the one that says 4ohm
http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=1+woofer&WoofImp= Dual+Voice+Coil+-+2+ohms+x+2
Username: Chevelle
Lancaster, Pa Usa
Post Number: 46
well it's wired in 2ohm and i had it hooked up stereo but my other sub didn't do this.That will give me a 8ohm load and cut the power down
Username: Goatin
U.S.A
Post Number: 177
if you bridge your amp it will be in 4 ohm so if your sub is 2 ohm you will have to wire it for 4 ohm impedance on the amp.
Username: Tjmutlow
Post Number: 1359
Just one sub, wire it series to get 4ohm load, then bridge amp, if it still makes popping/rattling sound, the sub may be on its way out.
