Please help with Fortec Star Lifetime Ultra
va_blue_stang
I am new to fta receivers, yesterday I flashed with a bin that would get bev but instead it killed the power to the receiver. I used jkey to jtag it but now the only thing it does when the switch is cut on is display 8.8.8.8 on the front display. Please help I have tried since yesterday with no luck. Also I tried wall and it cam up with an error that read "Warning the id code is incorrect". Is they're any hope for it.
Grimreeper
try loading the factory bin now
va_blue_stang
Do I load it with the uploader through the serial cable or with jtag cable. I have tried uploader and it will not communicate. What is the best uploader to try? Thank You For Your Help
Pepe Smith
try BL uploader and load 267 bin or 270 bin of Pansat2500a and use *last* button of your remote for number 0 (zero).
Username: Lklives
Post Number: 94
Do NOT use either of those bins on a Ultra..U will kill it!....go read the 100 files posted on how to Jtag that Ultra correctly...then put the factory bin on it once U get the nite rider lights...then put either the 256T clone safe pansat 2500 bin...or the latest 282T Ultra bin..
dsscommunity has a file called "Nagra2 Black Death Repair kit.zip" that will fix it...I think its in the Fortec area of forums..look around or do a SEARCH there..
Username: Lklives
Post Number: 95
Here's the Ultra factory flash:
[link removed]
here's the repair kit and some more info about the 8888888:
[link removed]&highlight=black+death
Pepe Smith
Lk,why until now my fortec ultra is running .Do I have a mistake for putting that 267 bin of Pansat2500a??
va_blue_stang
If the ird chip is fried will the 8.8.8.8 display still come on. Thanks for all the help
Username: Lklives
Post Number: 98
The 8888 is a nagra1 form of nite rider lights..just read the link, above I gave U, about the 8888...thats why I gave it to U!..The repair kit will fix it..
va_blue_stang
I still can't get any program to connect through the jtag cable or serial cable. neither one is seen on two different receivers. both are flu
Username: Lklives
Post Number: 110
Then U are NOT following the instructions!
Username: Newbie20
Post Number: 9
That will teach ya! DON'T USE BL's file/bin.
Username: Newbie20
Post Number: 10
Some people never learn.
va_blue_stang
Is there any way to test the jtag cable to make sure it is correct?
Username: Fire_fox
TEXUSA
Iv'e got a lifetime ultra, does anyone
know how i can get autoroll and bell
express vu!
Username: Fire_fox
TEXUSA
I went to dsstester.c*om and found a bin
file for autoroll. I would like to know
if anyone used this file on their receiver.
(Fortec Lifetime Ultra)
Full autoroll for DN & BEV manual keys
entry comfirmed working-5+days
converted pansat 2300 bin with fortec
remote codes added and clone kill removed.
(x-75bl-051222-247e-ir-api. use at own rick.
If you are using this file can you tell
me if it works good or did it burn your
receiver. Thank You
Username: Lklives
Post Number: 118
If U had read here, obviously this file can cause problems..
https://www.ecoustics.com/electronics/forum/home-video/189789.html
va_blue_stang
I took an ohm meter to check the connections. I noticed that all the pins for the jtag connection on the board are all reading that they are connected to each other and with the groung pins. I checked all of the solder joints under the main board and on top nothing is touching. Could this be the sign of a fried chip or something more simple that someone else has ran across and knows a solution. Also the .8.8.8.8 display still show but no menus or anything on the screen and the power button on the front isn't working to power it down.
Username: Lklives
Post Number: 121
AGAIN...U need to use then Nagra2 Black Death repair kit.zip file at dsscommunity..and ask for help there
va_blue_stang
I have checked all connections with a meter for continuity, the cable looks good but I noticed that all the jtag pins on the motherboard are showing that they are hooked together with the jtag cable unhooked and I noticed they are tied in withthe ground pins also. I have checked the solder work under the board and they are not touching each other. Any suggestions on what to check now. Thanks for all the help. Also I was able to get jkeys to communicate one time the first night but after that nothing.
Z-Diddy
I have the same 8.8.8.8. problem with Fortec Ultra due to a file I uploaded. How can I fix this? The links provided above http://dsscommunity*com/forums/viewtopic.php?t=6464 are disabled and the site has been moved...DssCentral*net - DssCommunity*com
!! Error 404 !!
The page you are trying to reach is temporarily unavailable or no longer exists.
Please advise if there is another site? Thanks!
Grimreeper
http://www. cyberman2ya.com/forum/index.php?showtopic=251 try this
coldgirl
this is working on fortec ultra but change the name to end with .bin
Username: Lklives
Post Number: 156
this site here Ecoustics will not let us type cetain other site names...so we must insert an asterik or space or something in the other site name and links...
COPY AND PASTE INTO YOUR BROWSER, THEN REMOVE THE * IN THE LINKS (C*OM)..
[link removed]
here's the repair kit and some more info about the 8888:
jitrum
Can anyone tell me how to change keys on a pansat 2500a. Now that we have nag 2. I'm using the 270 flash.
Username: Lklives
Post Number: 224
The 270 has autoroll...the keys will change by themselves automatically...and if U want to know how to manually input the keys,...then READ the thread/topic here " HOW TO INPUT KEYS" !!!!!!!!!
Dishboy
Lost Hockey Game Channels?
Since the bin change and re-scan, some of the channels which have hockey games are nowhere to be found...ca anybody help?
Channels: Skdl 1, skdl2, skdl3....are all gone?
Any help with this problem would be appreciated!
Username: Lklives
Post Number: 236
Then try another bin,like the 267...there are a ton of bins for the 2500!...and READ the "sports package" topic/thread here..
BTW...try blind scans ,sat scans, TP scans..etc..epecially right before the game starts..
Username: Getsah
Hello, I have a Fortec lifetime ultra (march 2005), and when I downloaded a bin, the system information changes, now it appears Al7barFTADiamond
Al7bar_2.76
Boot ver:6.1
10.jan.2006
When I try to download a new bin (Lifetime Ultra_050519_272_api(NTSC)), shows me this message "Flash update fail"
Please help me
Hi, guys can someone please send me nagra2 black death tool kit file. I have tried the site is always unavailable
Thank you in advance
