PANSAT PROBLEM :-(
Username: Endocrine_nav
i have a pansat 2700NS im pretty sure there the clones, but i have a signal lvl of 86 but no quality lvl. Also, i do not have a second pincode input in the parent control settings, do i have to upload something onto the reciver to recieve the second pincode input?
Also i am trying to connect with a bell express dish, what is the sigal name for bell? and the LNB?
gurdev
hey,
as far as i know the default keys are 0000, try that out... yeah you might need to change the key...
once your in then go to nargavision -> dishnetwork
then go down to 00 and press right 2 or 3x and see if the nargavision -1 changes to -2... then enter the keys for 00 then press enter to save it and then go upto 00 and press right again and it will change it to 01, you then can input keys for 01, press enter to save, exit... if you dont see the nargavision -1/-2 then you need update your receiver.
hope that helps!!!
