Which amplifier is good and compatible
Username: Llk
Alexandria, Va USA
hey guys, i desperately need help with this. I have no clue about car stereo, but i'm trying to get my boyfriend an amplifier for his bday since his burned out few days ago. He has two i believe 12" or 15" sony subwoofers, and i'm hoping that you could lead me in the right direction here as to which amplifier i should be looking for and which brands sound very good with sony subwoofers without it being too expensive. Thank you all sooo much
Username: Blainew
Post Number: 824
your gonna need to find out which exact subs he has first...
Username: Llk
Alexandria, Va USA
ok so his brother says they are 12" silver subwoofers 1400 watts each
Username: Kojak28
Augusta, GA USA
Post Number: 192
Lisa, we need a little bit more information. We need to know the RMS wattage of the subs. All sony car stereo equipment is overrated. Just FYI.
Username: Blainew
Post Number: 828
we either need the RMS and ohms per sub
or the model number
Username: Llk
Alexandria, Va USA
this is what I found on another website about the speaker, I'm pretty sure it is this one
Sony XS-LD125P5
Sensitivity: 89dB
RMS Power Handling: 400 Watts
Peak Power Handling: 1400 Watts
Impedance: 4 Ohm
Low Frequency response: 18Hz
High Frequency response: 2500 Hz
Diameter: 12 Inch
I hope this helps
best thing to do>get rid of anything Sony, they are not very good.
Username: N2audio
Lawrence, Ks USA
Post Number: 519
Lisa, don't let Anon get you down. P5's are decent subs and we can certainly find you an amp that will get the most out of them.
What are you looking to spend?
Off the top of my head I think this may be the ticket.
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14798
Username: N2audio
Lawrence, Ks USA
Post Number: 520
$10 cheaper here:
http://www.ikesound.com/product-product_id/2858
Username: Blainew
Post Number: 833
get a mono amp that does 800 watts rms at 2 ohms
wire both subs together in paralell to get a two ohm load
if the subs are 4 ohhm "dual voice coil" u need to still get a mono amp that is 800 watts RMS but at 1 ohm instead of two
Username: N2audio
Lawrence, Ks USA
Post Number: 526
they're dual 4's
Username: Llk
Alexandria, Va USA
thanks for the help guys, that really helped. Ur the best
