Hot to wire up the dual voice coil?
my friend just got an alpine 10 " type x sub and was wondering how to wire it up , he has a 500 to 1 PPI amp, coworker told me this is the site to get answers !!!
thanks to all who can help
Username: Blainew
Post Number: 822
is it 2 ohm dual voice coil
or 4 ohm dual voice coil
Username: Tjmutlow
Post Number: 1314
they only come dual 4 and if that amp is not pushin max at 2 ohms, prob not enough power.
Username: Blainew
Post Number: 823
http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=1+woofer&WoofImp= Dual+Voice+Coil+-+4+ohms+x+2&image.x=22&image.y=10&image=Submit
Username: Poorgtsowner
the amp is a ppi 500.1,
everyone thanks, hey blaine that site helped out thanks ill e-mail it to my friend hope it goes well, is that speaker good anyways?
Username: Blainew
Post Number: 825
yes it is good, i almost got 2..until i discovered RE
