PS2 Slim Console vs. Video Component Cable
Username: Mlbrownewell
I just bought a component cable and setup my PS2 system configuration properly... I use an Infocus Screenplay projector and the projector isn't picking up the signal format from the PS2. After reading several "same" threads, I'm beginning to see that this has become very common. The S-Video works fine and I have HD hooked up to the projector fine too. I'm pretty fluent with these type of setups, so I'm understanding there is some sort of video converter possibly needed. I use a VGA Component input in the projector and was wondering if anyone knew what type of converter or VGA box will solve this PS2 Component Signal to to be received. Then again, maybe I'm to ahead of myself. Is there a resolution to all these prior same topic threads? Any help will be greatly appreciated. thx
