My subs are smokin
Jack Dilan
i have 2 12's kicker l5s dual 2 ohm hooked up to a hifonics bx1600d amp wired to 2 ohms parallel
it pushes 1600 rms at 1 ohm and 1100 at 2 ohm
Is that the right connection or is it wrong
i have 0 gauge wiring
my subs started smokin after a cuple min of use
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 2018
sounds like your were clipping the h3ll out of the amp.
#1...did you set your gain correctly? or did you just peg them out and hope for the best?
#2...do you get a drop in DC voltage when the bass hits?
#3...do you have an HO alt and a deep cycle batt?
Post Number: 2019
by the way...if you have DVC2ohm subs and you wire them in parrallel, that will give you a 0.5ohm load.
you should have them wired in series-parrallel. (2ohms)
Username: Sploosh56
Ohio
Post Number: 1115
http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=2+woofers&WoofImp =Dual+Voice+Coil+-+2+ohms+x+2
Those are the only configurations that you can have. I'm sure you were jsut clipping the subs very badly. The kicker L5 and L7 subs are built poorly. Nothing like the round subs.
Jack Dilan
i wired them how they show on that rockford site to 2 ohms and wat should i set the gains to
i didnt put them all the way up just to 75% with only 3db bass boost
thanks for ur help
Jack Dilan
do i need to get a different amp or is this one good for them
Username: Young_james
Post Number: 744
I think you should worry about the subs more.....Do they still work??
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 901
lol yeh.. smoke usually means its dead or almost dead.. my 75% up you mean the gain was set at 75% up? it should be no more than a half at the most
Username: Lexuscoop
Post Number: 645
ouch.... dude, check your wireing and all that.... don't worry about the amp... subs are more important, if THEY are smoking
Jack Dilan
the reason why im not worried bout the subs is becuase i have warranty and can get new ones
So i wanna kno wat i should do next time when i get the new ones. if u can send me a wiring diagram and tell me what i should set my amp to and everything that would help alot
thanks
Username: Safe_cracker
Chicago, IL US
Post Number: 74
You think if you smoke them they are just gonna give you new ones? That's funny! Look under the warrantee, it is under "signs of abuse",lol. Polo..
Jack Dilan
well even if they dont replace it i can get new ones.
These still work too and i wanna kno what i should set my amp to; gains,low pass filter, subsonic filter, bass boost, etc. I also want to kno how i should wire the speakers up too.
Do i need a different amp too or is this one fine?
Thanks
Jack Dilan
bump
Jack Dilan
can you also explain how i was clipping the amp and what i should do so i dont clip it.
Username: 420pimp2
Post Number: 268
that sucks
Jack Dilan
so i still dont understand what i should do to solve this problem. What do i need to get to fix this any help would be appreciated.
Username: James1115
Wilton, Ct
Post Number: 4835
what head unit do you have? what is the pre out voltage of your Head unit? you need to match it to your amps input. Sounds like you clipped the hell out of your subs!!!!
