LK Help!--Setup with Multi Satellites/Receivers
va_blue_stang
I have read until I have confused so I was hoping for some help. I need to run four lnb's together and then split to go into three receivers. I have two C**lsat 5000 Platinums and a Fortec lifetime ultra. Any advice on what I need and how to set up the receivers to achieve this would be greatly appreciated.
killd da pansat!!
Hi, since this seemed like a good thread for someone to help here goes: My friend recently purchased a Clone Pansat 2500a. He put my Pansat 2500a (original) bin into it. I told him that it would kill his box but he said to continue. Now his box freezes up. Is there any way to fix it?!?!? Please help so I can finish this off. Thanks
Pepe Smith
from lnbs to disecq then to receiver. from receiver there is if output where you put your another receiver then to another receiver.
what is the confusion ?????? very simple
Grimreeper
You can use a dp44 switch has 4 lnb inputs and 4 receiver outputs
Username: Lklives
Post Number: 427
pansat..upload another bin,like the 101T or 256T
va...4x4 multiswitch
va_blue_stang
Would this type of switch work?
http://cgi.ebay.com/Zinwell-4803-4-x-8-Multiswitch-DirecTV_W0QQitemZ5859917795QQ categoryZ67880QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
