Help..................
Username: Help_pls
Princeton, Nj USA
I am not much of a techie, and all my installation is done by dishnetwork (have two dishes, one for 110&119 and another for 61.5), have one cable from wall to the receiver. I've subsc. for basic+local channels that i have still kept. When i look at setup screen of dishnetwork, it gives me following info.
Port 1: DB-Twin - 2 (110 even,odd)
Port 2: DB-Twin - 1 (119 even,odd)
Port 3: DB-Dual - 2 (61.5 even,odd)
Can someone pls. help me how this should be replicated on Pansat 2700A so I can all the channels from the above satellites??
Please, LK??
Killed the Pansat !!
Hi, since this seemed like a good thread for someone to help here goes: My friend recently purchased a Clone Pansat 2500a. He put my Pansat 2500a (original) bin into it. I told him that it would kill his box but he said to continue. Now his box freezes up. Is there any way to fix it?!?!? Please help so I can finish this off. Thanks
Bamboo1256
If his Pansat is a clone and not dead yet, I think you should re-flash it with a clone bin. But if it is dead then it is j-tag time my friend. Good luck!
Username: Lklives
Post Number: 436
help...EXACT same way...
