What brand receiver to match with Acoustic Research speakers?
Username: Salrmrcrey
CA USA
Post Number: 13
Hello All-
Anybody with feedback on choosing the right sounding receiver for Acoustic Research speakers? Thanks for the help.
Cheers,
Username: Jan_b_vigne
Dallas, TX
Post Number: 7398
Psssssst, AR is over fifty years old now. Which model?
CA USA
Post Number: 14
I will find out and get right back to the board. Sorry, the speakers are actually my sister's. She is looking for a receiver. Hold on tight.....
Cheers,
CA USA
Post Number: 15
They are the Edge series that you can hang on the ceiling or walls.
Username: Gman
Mt. Pleasant, SC
Post Number: 800
Most any receiver will drive these speakers. It all depends on your budget and what you want from your receiver. It also depends on how many speakers you are driving and if they are all the same.
