shamelessly fishing for input from Tim or anyone else on alegria audio's rosa lcr speaker. has anyone heard it or be able to characterize it? same drivers as ling, it seems, a bit more efficient than ling or emma..just curious
I designed it to be primarily home theater but it has such a nice sound it could be used for 2 channel as well. The tweeter is the same. The mid-woofs are similar but 16 ohm drivers wired in parallel rather than the single 8 ohm driver. I opted for a 4th order crossover at 5kHz rather than the 1st order at 10kHz to deal with the dynamics involved in HT. Bass response is a bit more controlled with the MTM configuration as well. Definitely a step up from Ling.
