Hello, I have an 18" dish with two dual legacy lnbs currently locked on 110 and 119. I have another 18" dish hitting 61.5 with one dual legacy lnb. I have 2 csat 5000 platinum receivers which I would like to hook up. I also want to be able to use both receivers at the same time?
... Can I use a dp34 switch and if so how would I hook it up. What settings would I need to set on my csat 5000 receviers?
Frank ...I already answered your question 3x here and 2x at dsscommunity..and so have others..in fact I recommended the DP 34 switch!...yes it works!...read to figure out the receiver config, its a 2 minute no brainer..same way U hook up cables to 34 switch..
Thanks again LK. I jsut want to make sure I dont waste any money. I read from many people that the DP34 switch is only good for DP lnbs taht is why I am still asking for more input. I jsut want to make sure it will work with MY LNBS. LET ME KNOW IF YOU CAN.
THANKS
ViniDomine
Sbroc - Research my friend, is the true nature of a tester: sometimes Google can give you some direct answers like these links below:
