Will subs in my trunk hurt my 6x9's in tne back?
Username: Goatin
U.S.A
Post Number: 104
Will subs in my trunk hurt my kenwood 6x9's in tne back? Can I put them in box's if so what size box should I use
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 930
if you have the rear speakers off with the subs going and just the pressure from the subs is moving the 6x9's, then its possible they could be damaged, but it'd take a lot to do that. you'll prob just get some distortion. you could put them in a box if you wanted, they make 6x9 boxes, not really sure on air space though. a lot of people will just take out the rear speakers, leaving the open holes for the subs to come through. really makes a difference if you can't have the back seat down and takes some pressure off the trunk, which will reduce rattles.
Username: Alteraudiousa
Concord
Post Number: 31
no you wont. Not unless you have a lot of subs back there thats moves alot of air. My one 15 didn't hurt mine.
Username: Solacedagony
New Jersey US
Post Number: 766
It probably won't hurt your speakers, but you may need to vent your trunk into your cab so the bass from the subs in your trunk gets into the cab.
