Jl xr650's vs diamond D6 comps
Username: Thigpen
RVA, Va Usa
Post Number: 414
which one will have better SQ, and which one would be better to go with my 2 12" SE's
alteraudiousa
i like the D6s. Good mids and the tweets were a little more towards my likings.
Username: Lil_jon
Post Number: 316
yall talking bout the diamonds that come in that lil suit case?
Username: Vinnyqh
Portland, OR
Post Number: 170
d6 will sound WAY better, i'd prefer the aluminum done tweeter with that speakers also instead of the silk dome one
Username: Jonathan_f
GA USA
Post Number: 5563
It's a toss up, try to listen to both if possible. I prefer the XRs, but that's just me. The D9s are better most definately, D6s are on equal ground.
