Infinity Kappa Perfect 12DVQ
Hi,
i have two infinity kappa perfect 12 DVQ and i dont know which sub i should get. I would like to keep it all infinity hardware but not sure if the infinity mono amps will be able to handle these two subs that great but if so please let me know which sub and how i would need to wire them.
Thanxs in advance
forgot to put this with the other post
the subs spec's are:
400 rms
1600 peak
dual voice coil sub
Username: Southern_bass
Paris, Tennessee U.S.
Post Number: 1025
dual 2 or 4 ohm ?
dual 2 ohm
Username: Do_em_dirty816
Kansas City, MO USA
Post Number: 41
register and we'll prolly help...iight anon.
Username: Midnightgixxer
i just registered and the main amps i am looking for is the one amp that would work best and what the best rms would be need to insure the best sound and power.
Can any one please help i need to know which infinity amp will be best for my Two kappa perfect 12 DVQ, which are dual 2ohm, with 400 rms and 1600 peak. the amps are the mono 611a with 657 watts RMS x 1 at 2 ohms, and a mono 1211a with 1300 watts RMS x 1 @ 2 ohms both by infinity. if i can get away with the 611a amp please let me know. thanx any one that helps.
