Alpine 6" x 9" 2-Way Coaxial Car Speakers with Hybrid Fiber Cones
Username: Mgreene
Maple Grove, Minnesota United States
Post Number: 15
are these speakers any good?
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 905
6x9's in general, don't sound very good. you'll get better sound from a 6.5 or 5.25 if you can make either of thoes fit in the 6x9 hole. alpine speakers are pretty good, have heard bad things about giving the Type S models externally amped power, they can't take it.
Username: Adddisorder
Post Number: 32
iv got 6x9s and they arnt bad they sound good and give me alot more bass then 6.5s...but i dont need a sh!t load of bass so if your putting in a sub just get 6.5s and you should be able to get this thing off ebay to convert 6x9 hole into 6.5 or you could just make one
