Hiding Speaker Wire
ChefSchipull
This may be a stupid question, but I'm a newbie....I will be setting up a home theater system soon, but I need to know if its possible to setup speakers up in the corner of my vaulted ceiling. If not, do they make a wireless home theater system out there? THanks
ChefSchipull
Username: Tbo44
To my knowledge, only samsung and panasonic make wireless home theater systems. But they fool you. They say wireless, but that only means the rear speakers don't have to connect to the receiver by the tv. the back speakers must be plugged into a rear "wireless" receiver and what do you know, you now have wires running in the back of the room. it's totally misleading, but it does save you from running "extra wires."
Username: Praetorian
Post Number: 57
TB is right on the money there... The "best" way to hide your wire is behind your wall or under the carpet.
As well, yes it is possible... advisable? I suppose that depends solely on the rooms acoustics and the avail of a ladder, a stud finder,...
Username: Homepro
Check Pioneer Digital Wireless Rear Speaker System (HTD645DV or HTD-540DV)or go to this url
http://www.pioneerelectronics.com and read about it .
JAbhau
I have a 40in LCD screen above our fireplace. I had to pull teeth to get my wife to go along with that. Now, I want the home theater and speakers to go with it.
This is our "formal" living area and I am trying to find a way to COMPLETELY hide the speakers without giving up a lot of sound quality. I am not concerned about the rear speakers, just the front and center ones.
Any ideas???
Username: Chitown
Post Number: 706
As a rule of thumb you have to remember that wireless=powerless. You can't have a speaker that magically gets powered through the air. At least nothing to speak of.
