Need help asap..installing this very min
Username: Zulkir
U.S.A.
Post Number: 51
how bad is it to rin the power wire with the rca cables? i got the rca cabls and the remore wires on the door frame adn woudl it be okay to run the power wire on the out side of that under the carpet nexto to rca cabls.when it gets to the back part of the car the power cabls and rca cabls will be coming out of the same spot.
Username: Fordpwr
Los angeles, CA Usa
Post Number: 400
i got mines set up similar to what your saying and it sounds great. just wrap the rca's with electrical tape
Username: B101
Queen City, NC USA
Post Number: 704
wrap with tape like he said.
or get some expensive rca cables with magnetic sheild!
Username: Nemen
Trinidad & Tobago West...
Post Number: 140
or you can get that tubing i forget what its called..........
Username: Zulkir
U.S.A.
Post Number: 55
i fixed teh prob..i tor my hoel car apart adn ran the power on the left side(side of batery) n took out my dash n ran the rca to the left.
