Running 2 amps??
Username: Goatin
Post Number: 11
how do you go about hooking up 2 amps do you need a capacitor?
Username: Tjmutlow
Post Number: 1223
most likely and you usually use a distribution block, and some amps have a line out pass through if running 2 sub amps, or use the 3 rcas on back of radio if it has them.
Username: Goatin
Post Number: 13
So if I get an amp with a pass through how would I rate the size wire needed? Do you just add total watts and go for a wiring package that fits? And are you supposed to set the wire fuse to the same as the total fuse ratings of the amps?
Username: Cadillacdb
Houston , TX
Post Number: 388
Bcae1.com check out number 16 i believe
Houston , TX
Post Number: 389
For all your Cap Questions refer to article 46
