Bronze Member Username: BretOkc, Oklahoma Usa Post Number: 23 Registered: Jan-06 | it sound nice in sealed but should i put it in a bandpass box will it sound better |
Gold Member Username: RovinTrinidad & T... Post Number: 5024 Registered: Jul-05 | bandpass don't sound as well as reg ported box which u should try 1st ........ |
Bronze Member Username: BretOkc, Oklahoma Usa Post Number: 25 Registered: Jan-06 | i have a seaed box and it sounds great but will it sound louder in a ported box and will it have a better risk of blowing |
Gold Member Username: RovinTrinidad & T... Post Number: 5026 Registered: Jul-05 | generally it depends on the Qts of a sub below 0.5 - its supposed 2 do better in sealed box above 0.5 - then ported is recommended NOT everysingle sub follows this rule though but its a good guide & in spite of this if u find 2 ur ears that a ported box sounds better when it should be sealed - then thats all that really matters ..... |
Bronze Member Username: BretOkc, Oklahoma Usa Post Number: 27 Registered: Jan-06 | bestbuy brand How can you tell the Qts |
Gold Member Username: RovinTrinidad & T... Post Number: 5028 Registered: Jul-05 | thats the problem with those cheap azz brands - ur lucky if they tell u what wrms cause all the label has is 1000watts with reputable brands u get a spec sheet which has it all . u can experiment with slot ported prefab boxes if u want cause they r only like 40 bux , look 4 correct vol & generally lower the Hz tuning the better ........ |
Bronze Member Username: BretOkc, Oklahoma Usa Post Number: 30 Registered: Jan-06 | what would u put it in for one its 800rms 1800peak gots 2 |
Gold Member Username: RovinTrinidad & T... Post Number: 5029 Registered: Jul-05 | info here http://www.the12volt.com/caraudio/theile.asp & on www.bcae1.com .............. |
Gold Member Username: RovinTrinidad & T... Post Number: 5031 Registered: Jul-05 | go to PA's website & see what info u can gather from there so u can figure it out ....... |
Bronze Member Username: BretOkc, Oklahoma Usa Post Number: 31 Registered: Jan-06 | thanks man |
