New member Username: Atomicracer12Post Number: 1 Registered: Jan-06 | I just baught the AudioBohn ABP10T:: -Power Handling: 600 Watts RMS -Peak Power: 1200 Watts -Sensitivity: 101dB -Frequency Response: 30Hz - 150Hz -Impedance: 4 Ohm Stereo http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem%26,1%26item%3D803005653 8&sspagename=STRK%3AMEWN%3AIT Can any one tell me how big of an amp I need? Recomend one? and if ya could could ya explain a little about them..im Realy to this whole amp thing i know NOTHING. |
Silver Member Username: B101Queen City, NC USA Post Number: 662 Registered: Sep-05 | single vc 4ohm sub. u need to find a amp that puts out 600rms, or even 500rms @ 4ohms. I will tell you now, that is a little tuff. You will end up spending for a good powerful amp, that puts out 600rms @ 4ohms. |
Gold Member Username: Mikechec9Http://www.cardomain.c... Post Number: 2038 Registered: May-05 | http://cgi.ebay.com/Phoenix-Gold-Xenon-X600-1-Mono-600-Watt-Amplifier_W0QQitemZ5 855957370QQcategoryZ18797QQrdZ1QQcmdZViewItem compare http://ikesound.com/product-product_id/3535 i personally prefer to put extra power in for added headroom http://ikesound.com/product-product_id/2169 however, if that bp stands for bandpass, then i would severely doubt the ratings on the sub. audiobahns are already suspect in that regard as it is. |
Gold Member Username: Mikechec9Http://www.cardomain.c... Post Number: 2039 Registered: May-05 | nevermind, clicked the link. guess it is a bp. |
New member Username: Atomicracer12Post Number: 2 Registered: Jan-06 | is this 600watt any good for my application??:: http://cgi.ebay.com/Kenwood-KAC-729S-Bridgeable-Stereo-Car-Audio-Amplifier_W0QQi temZ5857687956QQcategoryZ39734QQrdZ1QQcmdZViewItem |
New member Username: Atomicracer12Post Number: 3 Registered: Jan-06 | which one is the best for what i need?? http://cgi.ebay.com/NEW-PIONEER-GM-6100F-4-CH-AMP-600W-AMPLIFIER-107_W0QQitemZ58 56178186QQcategoryZ39743QQrdZ1QQcmdZViewItem#ebayphotohosting or http://cgi.ebay.com/PLANET-AUDIO-600-WATT-CLASS-D-MONOBLOCK-AMPLIFIER_W0QQitemZ5 856327684QQcategoryZ18797QQrdZ1QQcmdZViewItem or http://cgi.ebay.com/Sony-XM-SD46X-4-3-Channel-Car-Amplifier-Xplode-Amp-600W_W0QQ itemZ5856350599QQcategoryZ39745QQrdZ1QQcmdZViewItem or http://cgi.ebay.com/MTX-MXA6001-600-Watt-Class-D-Mono-Block-Amplifier_W0QQitemZ5 858059021QQcategoryZ64573QQrdZ1QQcmdZViewItem |
Gold Member Username: TjmutlowPost Number: 1178 Registered: Sep-05 | first off, stay away from the mono block amps, unless it is a Jl, or Pheonix gold Xeon series, they will not power correctly on a 4 ohm load, use an 600-800w 2 channel like the audiobahn a8002t, it is a reasonably cheap amp. |
