Myhair Unregistered guest | Good morning LK, Thank you so much for your help. Just to make sure what I'm doing here about the software part is correct. In dsscommunity I saw DSS Central File Share, Panset files. Should I download the lateset software from there? if yes how can I do the installation? The reciver should be on or off when I install the software. How offten should I update the software Thank you so much again and have a nice day. Myhair |
Bronze Member Username: LklivesPost Number: 54 Registered: Jan-06 | At dsscommunity forums, read the Panset set Up guide there..its also posted here in the ARCHIVES..and yes, U can download the software there (dsscommunity) too from the Pansat area of forums..or dsscentral File share area...either place U never have to change the software if U like whatever file u use...new software comes out ocassionally but it is NOT always an improvement or needed.. |
Bronze Member Username: LklivesPost Number: 55 Registered: Jan-06 | Remove the * in the .C*OM in the links below..then copy/paste into your browser.. Panset Set up guide.. [link removed] How to flash/upload files to receiver.. [link removed] Latest Pansat 3500 autoroll bin/flash file.. [link removed] Keymaster 2.0 Utility for getting Current keys.. [link removed] Pansat 3500 software uploader 3.37 [link removed] General Pansat 3500 Q/A Info.. Sat Info- Dish Pointing- How to's |
Bronze Member Username: LklivesPost Number: 56 Registered: Jan-06 | Remove the * in the .C*OM in the links below..then copy/paste into your browser.. Pansat Set up guide.. [link removed] How to flash/upload files to receiver.. [link removed] Latest Pansat 3500 autoroll bin/flash file.. [link removed] Keymaster 2.0 Utility for getting Current keys.. [link removed] Pansat 3500 software uploader 3.37 [link removed] General Pansat 3500 Q/A Info.. Sat Info- Dish Pointing- How to's |
Myhair Unregistered guest | LK, Thank you gain, I will do this as soon as I go home. Also how about the code? Does the code change often? if yes where can I get the new code? For some reason I couldn't find the Panset set Up guide also I dowonloaded (X-05bl_051102_119eubc_api)from dsscommunity under DssCentral File Share, Pansat file but this file didn't say anything about bin 136. I'm sorry to bother you with all of my problems. MyHair |
New member Username: Sanjeevm67Post Number: 1 Registered: Dec-05 | I have PANSAT 2700A reciever, Some of the channels have blacked out like CNN. How do I retrive these channels |
lucia4 Unregistered guest | Hi there: Having trouble setting codes for Bev. I have a pansat 3500 and the channels appear scramble can anybody help me. |
Myhair Unregistered guest | Hi LK, I did what you told me to do and I Registered with the dss but I never get an email to active my screen name. Do you know anyother way to download the files. Please help me I have been working on this problem over two weeks now. Myhair |
New member Username: KeanosPost Number: 10 Registered: Dec-05 | kyes for bell |
Myhair Unregistered guest | Hi, I have pansat 3500S finally after two weeks I was able to learn and install somesoftware (God knows if what I did right or not. The problem I have now, I can see the ch number but no picuter or sound, the screen flashes and stay black. Also every CH the signal strength is locked. At the point I have no idea what to do. Somebody told me I need the code for Dish Network but I have no idea where to get it from. Please help because I'm so tired of this. Thank you and have a good night. Myhair |
Bronze Member Username: LklivesPost Number: 61 Registered: Jan-06 | U need to align /aim the LNB's (eyes) on your dish towards the satelites U want...Dishnetwork 110-119 are most common..then U need to run RG6 cable to your receiver, and make sure U are aimed correctly and "scan" each satellite..next U need to configure your receiver..now install a disque switch between your LNB and receiver (closer to the receiver is better)...now flash the lateset software(bin 136 for the 3500) and upload it into your receiver...set the default keys...press SAT on remote and select echopackage..watch TV.. BTW...136 has newest keys in it and is an autoroll bin...U never have to input keys in it..new keys atomatically change and roll into it...BUT U MUST set the default key after installing/uploading the bin.. hey this spoon cannot get any bigger..U were given evrything U need ...now read! for dsscommunity problems and registration contact via email: atr-killer@dsscommunity.c*om or soullezz@dsscommunity.c*om |
Myhair Unregistered guest | LK, You are great and thank you so much. You thought me a lot, thank you. BTW I thought the Latest Pansat 3500 autoroll bin is 137 not 136. Should I just find the 136 and istall it or just use 137. About Keymaster 2.0 Utility for getting Current keys.. Do I need to install that too or the bin 136 or 137 enough. What is the setting for Echo3 (61.5). I hope this is the last time to bother you. thank you again and happy new year. Myhair |
Bronze Member Username: LklivesPost Number: 63 Registered: Jan-06 | Forget 61.5 ..its a another DN satellite with few channels..110 and 119 is more than enough satellites that U'll ever want or need.. USE 137 bin file...AGAIN,no need to input latest keys...they ARE already in that bin!..and whenever Dishnetwork changes the keys,they will automatically change (autoroll) in your bin 137 which will be loaded in your receiver...so U will NOT have to ever manually input the keys.. Keymaster is a UTILITY that U download and install on your computer desktop...it gives U the latest keys, IF U ever need to manually input them...its nice to have, just in case someday your receiver crashes or whatever..it takes 2 seconds to download and install on your desktop! So scan the 110 and 119 satellites (use the remote menu..installation...antenna etc) ...hook up the disque switch..configure the receiver (disque switch ports etc) using the remote 'Menu"..set the DEFAULT keys (remote-menu again)...might have to wait a few minutes for keys...now watch TV |
Myhair Unregistered guest | LK. Thank for your quicke respond and taking the time to answer all of my qutions. Myhair |
Myhair Unregistered guest | Good morning LK, Everything is working fine now and once again thank you for your help. LK, If at anytime I need to install a new bin do I just install it on the top of the old one or I need to flash the receiver first? If I have to flash it would you please send me the link or the name of the file just in case? I really appreciated your help, have a nice day. Myhair |
New member Username: RftsmtBuffalo Post Number: 1 Registered: Jan-06 | does anyone have new codes for the rex-1 |
Bronze Member Username: LklivesPost Number: 78 Registered: Jan-06 | Flashing is another term for uploading a file, any file, bin or not!...U can upload aka 'flash" a new bin aka "file" directly over everything already in receiver...some people always upload/flash the original factory bin first over the old one, then upload/flash a newer bin/file.. U'll have to SEARCH for the pansat 3500 original factory flash as I do not recall which one it is..I know its bin 221 for the 1500/2300/2500.. Go to [link removed] and register FREE...its the best forums for pansats..ask there for the 3500 factory flash...also they have best pansat discussions and latest files.. |
Bronze Member Username: LklivesPost Number: 81 Registered: Jan-06 | here's the Pansat 3500 factory bin..at future-fta.com [link removed] its zipped in a file called 3500.zip...uploader is also in the .zip file Pansat 3500S_050620_108_api(N).bin ...original factory bin for the Pansat 3500 |
mexlou Unregistered guest | I have the pansat 2500 and only getting the echo 7?? can't get 6&8 does anyone know why..I have the roll over but only getting one dish..need some help..thank you...what can i do?? |
dimelo Unregistered guest | hi can someone plz tell me the current codes as of january11. thank you |
Anonymous | does anyone know the new codes for Jan 11? |
Bronze Member Username: LklivesPost Number: 84 Registered: Jan-06 | Mexlou...read above U...3500 and 2500 are almost same...do same thing as I told "myhair"...except use the clone safe 267 bin.. No change yet in keys ...same as ones already posted here in New Keys thread..since 12-23..install keymaster which I linked above,then U don't need to ask for the keys here..and install autoroll bins, then never ask for keys or need to manually input them |
New member Username: TomyyyYakima, Wa Usa Post Number: 1 Registered: Jan-06 | how can i get the page from the computer for the favorite list or the page for download software via rs-232 serial cable |
Anonymous | Tom Garcia Go To Enjoy |
eyeintel Unregistered guest | Hello all, I have dishnet but I'm trying to find direct tv. I have a fortec but it shouldn't matter what receiver I have. I have two dish. I would like to pick up direct tv. If anybody know which satellite name is direct tv (echo, amc..etc)and the direction or position I need to direct my dish. Thanks |
eyeintel Unregistered guest | Hey, Look!!! you repeated yourself like a drooling immature halfbred that don't have anything but time on his hands. |
Bronze Member Username: LklivesPost Number: 87 Registered: Jan-06 | The DirectV (DTV) satellites are in the 101-110-119 orbits..The only way U can "pick up" DTV is by subscribing..DTV changed their datastream in April 2004 and it has NOT been cracked into since then.. IF U want To "test" satellite TV, U must test Dishnetwork (DN) and aim the LNB's on a dish at the 110-119 satellites where the DN birds are also orbitting..U have a long journey ahead ...good luck! |
Myhair Unregistered guest | Hello LK; My receiver is working great and thank you. What is the channel Master is? Can I make my own channel list, aslo I see $ next the channel number? I have two TVs one in each room, can I share the receiver in between the two TVs. I understand If I do that I will only be able to change the channel from the room where is the receiver is. Thank you for all your help. Myhair |
Arsalan Unregistered guest | Hey LK there is a big problem going on with me like my some channels are just black out and are not comming the channels are PAKTV(on 61.5), B4UMU(on 61.5), ARY(on 61.5) and some PPV Sports Channels do u know what the problem is, and I have fortec receiver as they are black out from couple of days and have no idea why they are not coming so please help me out in this one thnx... hope you reply |
Anonymous | I'm trying to donload file X-85BL_051223_270_AU_API.N, can anyone please send me the file? thanks |
xman27 Unregistered guest | Hi Can someone please point me to a link on where I can download the new .bin or .api ? file for my Fortec lifetime ultra, some instrcutions would help also. Thank you |
Pepe Smith Unregistered guest | 267 bin ok for fortec ultra ive been using it since bin 267 of Pansat2500A came and until now my stb still running and no problem. But i have to use the "last" button of my remote for number zero (0) |
Bronze Member Username: LklivesPost Number: 96 Registered: Jan-06 | Older receivers June 2004, then U can use the 267...new receivers will get killed..all depends upon which chip set is in receiver... |
New member Username: TomyyyUsa Post Number: 2 Registered: Jan-06 | I have a fortec star ultra life how can i make it work thank you please |
gl Unregistered guest | hi every body this is the first time I flash my pansat 2500a with 267 bin from the following website as some one in thins forum recomended I followed the instruction there but the reciever still not working can any one help please thanks the reciver was not working since september, because usually a frind of mine does it but he is out of the country now, so I decided to do it my self. thanks again |
rooky Unregistered guest | has anyone lost hbo-e, hbo-w, espn, tclip from their pansat echo 110 ,119 |
Gold Member Username: Maple_leafPost Number: 1247 Registered: Apr-05 | Need to rescan. |
PGG Unregistered guest | How to rescan a pansat 2700a ? because I lost almost all channels |
Anonymous | Rocky, HBOE, HBOW, ESPN, ESPN@, ESPNCL still working perfectly. Rescan your satellite. |
New member Username: Rbutler932Post Number: 3 Registered: Jun-05 | I need the file to get my pansat 2500a up and running where do I download the file?...Thanks Roy |
New member Username: BadgurlLancaster, CA USA Post Number: 3 Registered: Dec-05 | i need the new keys does somebody has them???? |
Anonymous | hi 2 u all if someone could help me in finding the keys for fortec i lost all the channels |
New member Username: WijeScarborough, Ontario Canada Post Number: 2 Registered: Oct-05 | does anyone know the new nagra 2 keys for dishnetwork?????? |
Letmeon Unregistered guest | just in FB D9 F2 D9 D6 C9 EF 7A 57 AD 32 24 67 42 6C E6 |
Bronze Member Username: WhatzzzupppMontreal, Quebec Canada Post Number: 17 Registered: Nov-05 | if someone could help me in telling how to enter the keys to the fortecstar pleaseeeeeeeeeeeeeeeee |
Bronze Member Username: WhatzzzupppMontreal, Quebec Canada Post Number: 19 Registered: Nov-05 | latemon could u tell me how to enter them through the remote |
vancouverman Unregistered guest | thank you letmeon..works perfect hey adam...go to parental control..0000 second pin..dishnet...go to nag2 enter in 00 and second set in 01 store...exit |
Anonymous | ECHOSTAR KEYS N2 Updated: Tuesday, January 17 2006 at 4:46 PM -------------------------------------------------------------------------------- Dish Network: N 0101 01: FB D9 F2 D9 D6 C9 EF 7A 57 AD 32 24 67 42 6C E6 Check out the January Specials at Bev: N 0901 00: 3C 4E A7 54 EE 92 3E 69 06 5F B6 88 9E BD 2D 1D N 0901 01: 6F 67 88 30 49 CA AF E4 4E C2 60 7B D6 77 1E E8 Enjoy King of electronics |
Bronze Member Username: WhatzzzupppMontreal, Quebec Canada Post Number: 20 Registered: Nov-05 | anyone can help me how can i download to enter the keys into the fortecstar please help meeeeeeeeeeeeeeeeeeeeeee |
mick_mack_23 Unregistered guest | I tried entering Key 01, but it wouldn't work. It just kept on saying Scramble/Bad Setting |
Bronze Member Username: WhatzzzupppMontreal, Quebec Canada Post Number: 21 Registered: Nov-05 | vancouverman could u please be more specified thnxxxxxxxxxxxxxxxxxxx |
Bronze Member Username: WhatzzzupppMontreal, Quebec Canada Post Number: 22 Registered: Nov-05 | vancouverman i forget 2 mention that i don't have the parental control if i want 2 download how 2 do it could u help me please |
Bronze Member Username: WhatzzzupppMontreal, Quebec Canada Post Number: 23 Registered: Nov-05 | hello anybody can help iam still waiting pleaseeeeeeeeeee |
JAI Unregistered guest | does anyone know if there is a new autoroll bin for the fortec star lifetime ultra? |
Bronze Member Username: WhatzzzupppMontreal, Quebec Canada Post Number: 24 Registered: Nov-05 | how do i download 2 get the parentel control on the fortec |
Bronze Member Username: Le74nguyenPerris, Ca Usa Post Number: 43 Registered: Dec-05 | New key for pansat 2500a Please...plessssssea my pansat 2500 down..nothing to watch now...help please...! |
Bronze Member Username: Le74nguyenPerris, Ca Usa Post Number: 44 Registered: Dec-05 | New key for pansat 2500a Please...plessssssea my pansat 2500 down..nothing to watch now...help please...! |
Anonymous | Plz help this time we have to put new keys stated as LETMEON or wait for the bin plz replyand also if any body tried that and it works plz reply thnx |
BUTT-BOY Unregistered guest | There is no safe autoroll for lifetime Ultra But I did find this at dsstester.c*om _This file works for Fortec ultra, Pan*sat 2500a original and clone Pan*sat Ultra, Multi Star, For*sat 2500 Ultra, Smart wave 2500a Date 06/12/2005 Download-260 clone-fix-Dec-06.zip (345,94kb) _I have not tryed this on my receiver...because Iam not to sure about it!!!! Maybe someone else might help U....ROTF |
intlms Unregistered guest | New bin file here for you to download. Enjoy. h**p://w*w.fortecfiles.com/attachment.php?attachmentid=1415 |
Bronze Member Username: Le74nguyenPerris, Ca Usa Post Number: 48 Registered: Dec-05 | THANK YOU YOU GUY...IT'S WORK GREAT ON MY PANSAT 2500A N1 00- 20-8F-2C-9B-8B-EA-0D-A3 01- 01-0D-A7-91-20-52-96-EE N2 00- FB D9 F2 D9 D6 C9 EF 7A 01- 57 AD 32 24 67 42 6C E6 |
New member Username: Gabe_bawaPost Number: 1 Registered: Jan-06 | New key for Pansat 2700A Please |
Anonymous | NEW KEY DISH: For Pansat 2700A and all Pansat's, Fortec's, and all other receivers. All use same keys. So do not keep asking for keys, they all use the same KEYS (active since 01/17/06): N2 00- FB D9 F2 D9 D6 C9 EF 7A 01- 57 AD 32 24 67 42 6C E6 |
Gold Member Username: Maple_leafPost Number: 1255 Registered: Apr-05 | Right above your post goof. |
Unregistered guest | Quick question.... I'm trying to upload the newest bin, but I have an Apple Mac. Is there any Mac version of "BLACkLIST UPDATER" to upload this bin? |
John Ann CO*CK Unregistered guest | @ Maple Leaf why don't U and LK go and BUTT fcvk each other....Mother fcvker!!!! Also S_U_C_K my dick while U are at it... Go and see the THICH-e-b!tch-eboy he love dick also...ROTF |
help me plz=) Unregistered guest | Hey...i was just wondering if i need a new bin file downloaded to my receiver or can i just add the new key and where can i get a good uploaded i keep having trouble with mine. |
Anonymous | Anonymous Posted on Wednesday, January 18, 2006 - 09:57 am: -------------------------------------------------------------------------------- NEW KEY DISH: For Pansat 2700A and all Pansat's, Fortec's, and all other receivers. All use same keys. So do not keep asking for keys, they all use the same KEYS (active since 01/17/06): N2 00- FB D9 F2 D9 D6 C9 EF 7A 01- 57 AD 32 24 67 42 6C E6 If these won't work, ill ask again |
help me again =) Unregistered guest | umm how do u use the pansat loader... it says download but it doesnt do anything and then it just says flash failed |
Silver Member Username: LklivesPost Number: 165 Registered: Jan-06 | Flash failed = defective or wrong cable or serial port..do not use USB ports or printer ports.. Pansat 1500/2300/2500 = straight cable Pansat 2700/3500 = null modem cable The cables all look identical.. |
Big Daddy75 Unregistered guest | where do i find an uploader for my pansat 2700A, also i need a new bin. Thanks |
New member Username: Webspyder01Post Number: 1 Registered: Jan-06 | Hello! I`m a newbie , and have a 2005 Fortec star ultra, been trying to figure out instruction on how to download bin (and where from) ect. Will anyone advise me? Thanks.. |
Anonymous | how to enter key for dish network in eagle star receiver, tried as per pansat 2500a but nagravision 2 can't show up? Pls help....... |
New member Username: Mdl97Post Number: 1 Registered: Jan-06 | does anybody have the code for dish network yet.i tried putting these that are on this site with no luck.any help will do please |
Unregistered guest | SORRY FOR ASKING BUT IS THE NEW BIN FILES OUT FOR THE PANSAT 3500S I CANT SEEM TO FIND IT |
Unregistered guest | how to upgrade STRONG 4820 |
slinky1222 Unregistered guest | Linda Posted on Wednesday, January 18, 2006 - 05:25 am: -------------------------------------------------------------------------------- THANK YOU YOU GUY...IT'S WORK GREAT ON MY PANSAT 2500A N1 00- 20-8F-2C-9B-8B-EA-0D-A3 01- 01-0D-A7-91-20-52-96-EE N2 00- FB D9 F2 D9 D6 C9 EF 7A 01- 57 AD 32 24 67 42 6C E6 Can someone please be super clear about how to do this: i have a pansat 2500A go into parental control and then nagravision then i get: Provider ID: 00 01 Key: 00 Key Data: _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ then you put the key here and then do the same for key 01. i dont know what im doing wrong. please help. thanks in advance |
Maya_M Unregistered guest | I have pansat 3500S and I found that storing a channel in favorite is a Pain in the A.. Does anyone know a way to store a channel to Favorite while watching the channel. One thing I don't like about the 3500S is that I can't see the channel that I want to add. When I use Channel Edit, Favorite it shows only the channel number with out picture. Thank you all What is the a beetr R Viewsat or Pansat? |
Anonymous | anybody got anything for europian chanalss plase |
Unregistered guest | Hi everyone this is the key for pansat 2700A and it's works very good N2 00- FB D9 F2 D9 D6 C9 EF 7A 01- 57 AD 32 24 67 42 6C E6 |
Anonymous | Can anyone let me know please how to get the NBA league pass channels to work on Foretec ultra ? and let me know tooo if there is no solutions to get them working thank you |
Silver Member Username: LklivesPost Number: 185 Registered: Jan-06 | READ...I've explained it, step by step, 1000x here...read the "Sports package" thread! |
Anonymous | sorry LK i dont mean to be a hastle but i need two favors from u please 1- where do i get the software to program my fortec Ultra 2- If u dont mind telling me again because i looked all over the site and i didnt find the Sports Package instruction if i missed it just copy paste it for me. sorry im just new to this thanks man |
mugabe Unregistered guest | I have spent the last 30 minutes going over the posts in the forums and I got answers about my Fortec Ultra Issues. Why am I ranting?, because there are some twits out there who want to be spoon fed - asking ?s about issues that are discussed in the preceeding posts - pple lets be serious - take a few minutes to read prevoius posts B4 u ask ?s that show deprived logic & reasoning. |
New member Username: Kevin312Post Number: 1 Registered: Jan-06 | I HAVE A PANSAT 2500 A HOOKED UP TO AN 18INCH DIRECT TV DISH WITH THREE LNBS FACTORY SET AT 91, 110 & 119 WONDERING HOW TO CONFIGURE AND BEST BIN TO USE. i PRESENTLY HAVE A 256 BIN AND ALL THREE LNBS SET TO STANDARD WITH DISEQ SET TO OFF POSITION. I THINK WHEN I SCAN EACH SATELLITE i AM JUST REPEATING THE SAME CHANNELS OVER AND OVER. i ONLY GET( HBOCY AND HBOLT ) OF THE HBO CHANNELS IF THAT HELPS DETERMINE SAT THAT IS WORKING , WOULD LIKE TO SET UP BOTH BEV & CHARLIE |
jeepnee jake Unregistered guest | STOP YELLING!!! jeez some people. |
New member Username: Kevin312Post Number: 2 Registered: Jan-06 | Sorry !!! Sorry !!! Sorry !!! |
New member Username: ChickPost Number: 1 Registered: Jan-06 | Hey All, I'm new to this site, and i was hoping someone could help me? i have a dishnet Pansat 3500s receiver, how do i set it for the greek channels? Don't ask it keeps my parents happy! any help would be greatly apreciated. |
Anonymous | i need key for pansat 2500 A |
Anonymous | mugabe do me a favour and mind ur own business ok. Im new to this site so dont try to act smart .and ur the twit watch ur mouth. |
Anonymous | LK i just to need to know if its possible to get the NBA league pass channels to work thats all Thank you |
mugabe Unregistered guest | Struck a nerve!! oops Watch out pple there is a virus on some of the bins - the virus is called W32.pfini and it attaches itself to .exe files, not dangerous but spreads very fast on shares (networked nodes)and modifies registry entries - its easy to clean but its kind of an irritant scan the bins (dish-bev bins), Blacklist Uploader, Gtrom and the likes b4 use. Having said that my Fortec does not download or write any bins, it just stays at 0% and gives a download error.What is the best way out? I am using N283t I also changed the keys to the active ones but all in vain. |
New member Username: MugabePost Number: 1 Registered: Jan-06 | This is my ID |
Gold Member Username: Maple_leafPost Number: 1272 Registered: Apr-05 | Ugly dog Champ. |
punjavi doo Unregistered guest | and blurry |
rock06 Unregistered guest | new keys for pansat 2500a please anybody,thanks |
ULTRA x Unregistered guest | NEED HELP PLZ TRYIN 2 JTAG MY FORTEC ultra WITH JKEY and it returns this "The flash codes returned are not recognized by jkeys.Mfg/Device Codes returned are FFFFFFFF/FFFFFFFF(JEDEC) and FFFFFFFF/FFFFFFFF(Flash File) what can i do THANKS FOR ANY HELP |
Unregistered guest | HI THE LAST BIN FILE I USED FOR THE PANSAT 3500S DOSE NOT WORK,THE MEMORY CARD STILL HAS THE OLD BIN FILE, QUESTION DID A NEW BIN FILE COME OUT, AND IF NOT DOES ANYONE KNOW WHEN THE NEW ONE WILL COME OUT,SORRY IM NEW AT THIS AND NEED HELP, I KNOW I HAVE TO LEARN ALOT |
