I've tried everything like the manual says, but no luck. I try to set it up through Windows Media Encoder to use on Windows Messenger, but it seems all I get is audio, no video. Do I need a tape or SD card in the camera for USB Streaming? Or is it maybe that my PC just won't preview the video stream?
ANYONE ELSE HAVE SAME OR SIMILAR PROBLEMS? I would appreciate any help.
lsbking
When I go to use Windows Messanger, and I use the Audio Tuning Wizard, all I get in the Video Preview Screen is a black screen.
friendly
The problem keeps getting wierder. After reading alot of message boards and trying a bunch of crap I noticed that when I did everything according to the manual my PC picked up audio, but no video. Then if I go into the camcoder menu (you have to disconnect the USB cable to do this) and go to ADVANCE > USB FUNCTION > MOTION DV, and then connect to computer, now the video works fine BUT NOT THE AUDIO!
Any help on this fix? I really want to get a webcam setup. This is frustrating.
