Username: Jprix82 Post Number: 39 Registered: Jan-06
Sunday, January 22, 2006 - 12:26 GMT Anybody tested any XX Hifonics amps and do they put out their rated power?
Username: B101 Queen City,
NC
Post Number: 575 Registered: Sep-05
Sunday, January 22, 2006 - 16:40 GMT SURE Hifonics XX Zeus (1600 watts & strappable) Hifonics XX Hercules (2000 watts & strappable) Hifonics XX Thor (3000 watts & strappable) Hifonics XX Cyclops (4000 watts & strappable) Hifonics XX Goliath (5000 watts & strappable)
Username: Jprix82 Post Number: 42 Registered: Jan-06
Sunday, January 22, 2006 - 17:16 GMT so the XX hifonics put out what they say unlike the brutus series.
NC
Post Number: 599 Registered: Sep-05
Sunday, January 22, 2006 - 18:40 GMT You will be very happy! Especially for the price of that power!
NC
Post Number: 600 Registered: Sep-05
Sunday, January 22, 2006 - 18:42 GMT bump; my threads dont move.
Username: Tdbdadrummer Wellsburg,
WV
Post Number: 1159 Registered: Aug-05
Sunday, January 22, 2006 - 18:44 GMT The only downfall to those amps is how much space they take up...But does the 85% of RMS output apply to these amps as well?
NC
Post Number: 604 Registered: Sep-05
Sunday, January 22, 2006 - 19:39 GMT The thing with these hifonics, you will have to give more voltage to get full power. When tested at 12volts they are a little low. Give them 15volts then its a totally different story. Lower their impedance, then its a totally diffrent story! Man that thing is stable to half ohm! they just dont say it! Tyler u are sure to see Hifonics at the competitons. Hifonics XX are the Dclass amps.
Username: Jprix82 Post Number: 43 Registered: Jan-06
Monday, January 23, 2006 - 00:25 GMT So if i get the Hifonics XX-Colossus II i could push 2 15" Re SX at 1/2 ohm?
Username: Jprix82 Post Number: 44 Registered: Jan-06
Monday, January 23, 2006 - 00:30 GMT I mean the Hifonics XX Hercules not the Colossus.
NC
Post Number: 620 Registered: Sep-05
Monday, January 23, 2006 - 02:13 GMT it will be perfect. to get full power out of the hifonics xx hercules you need to run it less than .7ohms or abit less. =D
