Username: Adddisorder Post Number: 23 Registered: Jan-06
Thursday, January 19, 2006 - 20:25 GMT i need a 4 channel amp i have 6.5s 65rms and 6x9s 80rms would a 4 channel amp around 75 watts be good for this also any suggestions on a pretty decent cheap amp?
Username: Carguy Post Number: 5206 Registered: Nov-04
Thursday, January 19, 2006 - 20:32 GMT There are some good amps on eBay. Try some of the old RF, PPI PC/PCX series, Art series, JBL, Orion, MTX, and Audiobahn 4100T (I think). You should be able to find 4 channel amp for $200 or less from the above brands.
Username: Tdbdadrummer Wellsburg,
WV
Post Number: 1057 Registered: Aug-05
Thursday, January 19, 2006 - 21:01 GMT I like my A6004T...65W RMS @ 4ohms x 4...
Username: James1115 Wilton,
Ct
Post Number: 4563 Registered: Dec-04
Friday, January 20, 2006 - 17:44 GMT PPI 480 pcx is a very nice amp for your application
Ct
Post Number: 4564 Registered: Dec-04
Friday, January 20, 2006 - 17:49 GMT PPI 480 pcx is a very nice amp for your application
Ct
Post Number: 4565 Registered: Dec-04
Friday, January 20, 2006 - 17:52 GMT PPI 480 pcx is a very nice amp for your application
Ct
Post Number: 4566 Registered: Dec-04
Friday, January 20, 2006 - 17:54 GMT ppi pcx 480 would work great for you I have used thiat amp and the pcx 4100 they are both nice amps.
Username: Loc_out Post Number: 286 Registered: Feb-05
Friday, January 20, 2006 - 18:32 GMT James what is the output on that Amp?
Ct
Post Number: 4573 Registered: Dec-04
Friday, January 20, 2006 - 18:39 GMT 4x80 on the 480 and 4x100 on the 4100. Those ratings are at 12 volts
Username: Loc_out Post Number: 287 Registered: Feb-05
Friday, January 20, 2006 - 20:58 GMT What kind of speaker did you have on the 4100 James?
Ct
Post Number: 4579 Registered: Dec-04
Friday, January 20, 2006 - 21:36 GMT I had infinity kappa 6x8's on the rear and boston acoustic pro 6.5's on the front in my wife's car.
