I have 2 P3104 subs 400 RMS 4 watt that I need help on getting amps for. I used Sony mono amp, but the amp failed after a while. i'm thinking of getting either VIBE1800D 1 x 400 Watts RMS at 4 Ohms or Audiobahn A8000T 1 x 400 Watts RMS at 4 Ohms or Rockford Fosgate p6001 300 watts RMS x 1 at 4 ohms 600 watts RMS x 1 at 2 ohms.
Questions:
Should I wire the subs paralel to 2 ohm or keep it at 4 ohm? I don't want to overpower the subs and ruin them.
Which amp should I get for best setup? I should probably go with Rockford P6001 amp, but if I do, should I get 1 amp for my subs or 2 amps, one for each?
