5x7 to 6.5
Username: Xunodostresx
Bluffton, SC Beaufort
Im putting 6.5 in place of 5x7s and i have extra space around that. would that mess the quality of sound?? And any suggestions on 6.5s???
Username: Rovin
Trinidad & T...
Post Number: 4825
no it would improve it ALOT - especially if done with components !
check out
Infinity
Mb quart
JL
Alpine
Diamond
Username: Tjmutlow
Post Number: 1016
you want to use a plate or something to seal the space up..
Username: Tdbdadrummer
Post Number: 980
RE components as well...
Username: Adddisorder
ha i had the same question. but what would you fill in the space with, ply wood???
Username: Tjmutlow
Post Number: 1023
1/8 wood, dont need much.
Post Number: 14
i did it but used thicker wood just because its all i had and they sound awesome...the only problem is the door panel woulndt fit on right so i had to cut a hole for the speaker out...and right now it looks bad but im redoing the interior anyway so i had to get to the doors sooner or later
