Unregistered guest |
Posted on INSTRUCTIONS TO CHANGE THE REGION CODE VIA REMOTE CONTROL FOR INITIAL IDM-850B; 1. POWER ON 2. PRESS 'SET-UP' BUTTON 3. SELECT THE 'PREFERENCES' MENU (PRESS CENTER ARROW BUTTON THIS IS THE ENTER BUTTON) 4. INPUT THE PASSWORD CODE (2,2,4,4,5,5) 5. PRESS 'LEFT' AND 'DOWN' BUTTON (NOW THE SCREEN WILL SHOW 'REGION CODE 1') 6. PRESS NUMBER BUTTON (2 TO 6) TO CHANGE ZONE. (TRY 10/0 BUTTON FIRST, IF ACCEPTED THEN PRESS SETUP, YOUR PLAYER IS NOW REGION FREE) 7. PRESS 'SETUP' BUTTON TO EXIT |
