New member Username: MrlorenChulaJuna, CA Post Number: 7 Registered: Nov-05 | Hello, My house came pre-wired for HT setup. everything went together fine I used wall plates with jacks to hook everything up. Well for the sub wire the builder used some kind of #24 four wire that is tin foil insulated and out side the insulation there is a bare wire running just under the outer jacket . I had to buy an RCA plate with screw on terminals for it. Now when my receiver is off I get a HUMMM from my sub. I ran a stock RCA over the floor to the sub and the hum was gone! When I hook it back up to the pre-wire back comes the hum. Could the bare wire be a ground wire? If so what do I ground it to? I called the builder and they said to call the subcontractor who did the job. So I called them, they would not tell me a dam thing and wanted $300 to come out and hook everything up. I told them that I had it all hooked up and was just needing help with the sub wire. They said if we come to your house its $300 no matter what. Can some one here help me save $300??? PLEASE Thank You |
New member Username: MrlorenChulaJuna, CA Post Number: 8 Registered: Nov-05 | This is the wire they used http://www.allelectronics.com/cgi-bin/category.cgi?category=825%26item%3DPLC-4&t ype=store what could I hook the drain wie to? |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 7010 Registered: May-04 | The link doesn't load. I would just ignore the drain wire and use the internal cable only. |
New member Username: MrlorenChulaJuna, CA Post Number: 9 Registered: Nov-05 | well, I think I fixed it. I hooked up the drain wire on one end only, the sub end to the - terminal. well it worked like a charm. NO more hum and the sub sounds just as good as if where hooked up with an RCA cable. I stayed up all night last night reading off the internet and found this to be the answere. I had to do about 20 different google searches to find it. Dam contractors just want to make money. |
New member Username: Rockford15x4Vernon, B.C. Canada Post Number: 1 Registered: Jan-06 | Hi my home theater: harman/kardon avr 130 front=Quest qt88 tower speakers rear=Quest qt88 tower speakers center=Quest qc5 subs=rockford RFP4815 x 4 amp=MTX mxa6001 1 farad cap moto master bower box My problem is when the charger is hooked up to the battery it makes a humm. everything else workes fine its just that humm. what can I do, is there a power filter i can buy or am I stuck with the humm. any feed back would be helpfull thanx |
