Bronze Member Username: Bigjohn6973Post Number: 44 Registered: Dec-05 | Just wondering what some of yalls opinions are on Memphis' high wattage amps and Orion's high wattage amps? Which put out the most "true" power. Any suggestions would be appreciated. |
Silver Member Username: B101Queen City, NC USA Post Number: 427 Registered: Sep-05 | both do their rated power & a lil more. what specific modles are u looking at? |
Bronze Member Username: Bigjohn6973Post Number: 49 Registered: Dec-05 | B, I was looking at the Memphis 4k amp and the Orion 2500. I'm not looking to buy neither at the moment but soon I want to upgrade to something very powerful. So in your opinion, which one would you get? Oh and what about the Hifonics Goliath series? |
Silver Member Username: Southern_bassParis, Tennessee U.S. Post Number: 749 Registered: Dec-05 | orion 2500....thats a beast |
Silver Member Username: InvictuzSeattle, Wa Usa Post Number: 197 Registered: Jan-05 | i have a 2500d..nice amp, very versatile. Has dual speaker outputs (two positive and two negative) so there are plenty of wiring options http://www.orioncaraudio.com/amps/Dmono.asp |
Silver Member Username: B101Queen City, NC USA Post Number: 449 Registered: Sep-05 | I have to say that the Memphis4KW will EAT the Orion 2500d.. That thing is 4000RMS @ 1ohm! with ANL inline fuse, 0ga connections, They recomend a NEW charging system. So you will diffenatly need ALOT of JUICE to power it... The Goliath is use alot in competions also. You can allways get 2 of the Orions. I personaly like Memphis stuff, they are well made. I would pick the Memphis or ORion over the Hifonics. |
Silver Member Username: Redbone15367Mo U.S.A. Post Number: 140 Registered: Sep-05 | The orion is very impressive. I have 1 and am looking for another. Consider the cost of 2 2500d's vrs. 1 mojo. |
