Username: Greeney88 Http://www.freewebs.co...,
Minnesota
US
Post Number: 78 Registered: Jan-06
Sunday, January 15, 2006 - 18:00 GMT can anyone walk me through on how to do this? Thanks!
Username: B101 Queen City,
NC
Post Number: 474 Registered: Sep-05
Sunday, January 15, 2006 - 18:02 GMT lol what is the minimum ohm load on your house stereo? they are normally 8ohm, some are 4ohm stable! if u hook up a 1ohm load or 2ohm, it'll go pop! it should be written in the back of it!
Minnesota
US
Post Number: 79 Registered: Jan-06
Sunday, January 15, 2006 - 18:12 GMT 6 ohm max it says
Username: Graphix1 Santa Rosa Heights,
Arima
Trinidad & T...
Post Number: 566 Registered: Oct-05
Sunday, January 15, 2006 - 18:27 GMT ive been doin this as long as i can remember... whats the brand of that stereo.....panasonic.. i used to run a 4ohm load on my 6ohm stereo and nothing ever happened,and i used to turn it up all the way 2 they should start making 1ohms stable home stereos.....people will be getting like 1000wrms,thatll be cool...lol
Minnesota
US
Post Number: 80 Registered: Jan-06
Sunday, January 15, 2006 - 18:33 GMT its a sharp
Arima
Trinidad & T...
Post Number: 568 Registered: Oct-05
Sunday, January 15, 2006 - 19:00 GMT ya well that should be able to take a 4ohm load......try it and c.... But if it starts to get hotter than usual then u know somtns wrong...
Minnesota
US
Post Number: 81 Registered: Jan-06
Sunday, January 15, 2006 - 19:06 GMT k so all i need to do is just plug in the speaker wire to the back of the sterio and i should be set
