MultiStar unit with no sound and remote not working
New to this so hope someone can help.
I have a MultiStar unit programmed and I can see all channels(changing on the unit) but the sound is not there and the remote does not work.
Does anyone have any idea where I messed up?
Thanks
Username: Manofsteel
Forgot to say that it is programmed as a Pansat.
It has worked in the past so I must be missing something this time.
I am now regisered
Username: Lklives
Post Number: 120
Suggest U use [link removed] for help..they are best in that area
Letmeon
My Multistar is going strong ,no problems , since last May,2005.....
had it programmed with proper bin, not hacked ones that have a few surprises popping up..
Yes DN plays with ur mind.......
