I recently started subscribing to DirecTV in order to get HDTV, though I'm still saving $$ for my 60" Sony SXRD. Acordingly, I am viewing my new DirecTV signal on an older model Sony rear projection TV. My new picture is very disappointing. Everything looks washed out or white-ish (not snowy). My old BellSouth cable was far superior and the DVD and VCR pictures still look fine. Over the phone trouble-shooting was unhelpful, so I will probably have to get a technician out (not sure if it will be the same one who did the install). Meanwhile, any thoughts from this auagust forum would be very welcome. FWIW my signal is played through the Sony's VHS option, rather than Video 1 or Video 2, etc -- I have no idea if that matters. Many thanks.
Hey Mike; More chances of help at the correct forum, try DTV, this is FTA, just testing to see if we can get free sh1t and then deleting immediately...LOL
LK or whomever, Which forum is appropriate? I checked and this one seems right. As my unsername reveals I'm admittedly an amateur -- don't even know what DSS is. But it looked to me like this is the forum for satellite and DirecTV. What am I missing?
Grimreeper
what are you using to hook to your tv Svideo,rca cables,coax? Svideo into the video 1 or 2 would have the best pic unless you have RGB component wich puts out the best picture
Beat_This
Mike, if you want best picture, use either S-Video, Component or RCA, if you want the best picture possible, use Component and best of all is HDMI cable for superior quality. It is all your connections and nothing else. If you need help more about this, you should check some Home Theater forums on this site and other sites. This is to do with your connection and cabling setup and nothing to do with your receiver or DTV unless there is a receiver problem or Dish alignment problem. Good luck!!
