ok i too off the top over of my amp, like the metal thing. i took out the fast so i could re-mount in a different spot. im planing on putting a plexiglass sheet over the amp so you can see it work and all that fun stuff. but i have to re mount the fans becuase in the spot they were stock the amp was getting REALLY hot on the other end. the fast are going one on one side and the other on the other side, but to pount the fans where i want, i have to super glue to some components on the amp, should i do this or will it mess the amp up?
