is it some way possible that a 1200w rms amp from one brand be more powerful than a another brands 1200w rms even if both brands are ces-2006 certified?
If it's CES rated, it's suppose to give you the rated power at given volts. Actual amount of power will vary depending on the power supply. Unregulated ps for example will give more power at higher volts.
