i have one kicker comp vr12 and a pyramid 800w 4ch amp. could some one tell me or show me a way to get all 800w to my sub without hurting it in the long run. thanks
IF you have a dvc 4 you can bridge each pair of channels for each coil, but make sure you have crossovers and gains set as close to the same as possible. This is an usual method and I would recommend selling that amp and getting something more practical, but it will work.
If it's a dvc 2 you can only use two of the 4 channels.
