Silver Member Username: Dakulis
Spokane,
Washington
United States
Post Number: 773 Registered: May-05
Posted on A TDL center with the same or very similar components if you're trying to timbre match or another TDL KVI used as the centre. Otherwise, you're unlikely to get a true timbre match with another manufacturer's center. |
