SQ
Username: John_wash
Nashville, Tennessee
Post Number: 96
does sound quality really matter if your subs are in the trunk. jw bcuz it seems like you really cant tell how they sound. You just hear the loudness of them.
Username: Blainew
Post Number: 586
you can tell the sound quality
like i can definatly tell that two audiobahns in a bandpass box dont even compare to a JL audio 12w7
also the amp and box have much to do with SQ
Username: John_wash
Post Number: 97
so even though it would be in the trunk you still can tell
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 4019
yep, just like u can tell the diffrence between night and day.lol
Username: Blainew
Post Number: 593
yep
but i mean..all subwoofers will make bass
i ahve two audiobahns hahah they are probably the cheapest subs you can buy..i just wanted bass and i wanted it cheap
but i will be upgrading bigtime soon
Username: Blainew
Post Number: 594
yep
but i mean..all subwoofers will make bass..so if u just want some booming bass...get some cheap subs..and dont overpower them
Username: Southern_bass
Paris, Tennessee U.S.
Post Number: 595
yep the quality DOES matter..you can definately tell
Username: John_wash
Post Number: 100
ight pres8 the responses
