Philips TV with No Power
Username: Thelegoguy
Hello folks,
New guy here. Just wanted to know if anyone had any experience with a 27" Philips TV that for some reason just won't turn on. Tried the remote, tried the front POWER button, yes it is plugged in, and I have tried on different outlets in different rooms. Haven't really gone beyond that yet. If it helps...it's model #27PT6441/37. Thanks for the help.
-John the Legoguy
Hey John,
I have the exact same problem with the exact same tv. It died yesterday. Looked online and it seems to happen to a lot of people. One person mentioned he was able to fix it by replacing the fuse. It appears to be a T4Amp, 250V fuse. I can't guarantee that will work, but I'll be buying one from Radio Shack tomorrow to give it a try since it's only $2. Hope that helps.
Thanks man,
I will pull the covers off and start checking fuses. Thanks.
Hey man,
Just wanted to say thanks. I found the little fuse and it was blown. I went to radio shack and paid 2.50 for a 4 pack. Replaced the fuse and it turned right on. Thanks again.
-John the Legoguy
