S-vid
Username: Dgh
When I hook up a s-vid cable I get a worse pic than I get with coaxal,I thought s-vid is better than coaxal cable
Username: Slo_hand2
Post Number: 325
I t is there must be something wrong with the cable.
Username: Maple_leaf
Post Number: 1235
Change your a/v settings to s-video.
Username: Thehitch
Fla.
Post Number: 292
Hey Dave H.; If you are running in series from more than two components i.e stb-dvd-vcr-av receiver, etc., I believe they all must be linked via s-video, you can`t mix and match connections.
Username: Dgh
Hi Thanks for the replies
Maple Leaf,can't see were to change the a/v settings I have a Toshiba 52hm85
Thehitch,I had the cable straight to the tv from the satelite
Username: Dgh
Is better to spend bigger bucks on a cable,Is there really a big diference.
