Proper setup
Username: Caraudiofanatic
Post Number: 22
would a hifonics tx1505 mono class d amplifier power two audiobahn alum12n subwoofers. they are dvc 6ohm 1000 watts rms 2000 watts max. i would have to run them at a 1.5 ohm load which both would be seeing about 750 watts per sub. would this work and hit just fine. plz reply asap.
matt
Username: Tjmutlow
Post Number: 969
that amp will never see that wattage, overrated and it probably is rated at 14.4 volts, so i would guess that that setup may see 900w to the subs.
Post Number: 23
per sub or both thanks.
Username: Tjmutlow
Post Number: 970
both
Post Number: 24
well then what about a digital audio 1000 watt mono. would that work it is fixed up to where each sub sees 1000 watts. thanks.
Username: Tjmutlow
Post Number: 972
do not know much about them, but unless it is rated at around 13volts, your never going to see max from any amp unless your charging system is made for it.
